12v Aux Output
- mtbspeedfreak
12v Aux Output
01 Jul 2011 18:19
How's the best way to wire up a 12v aux. output (cigarette lighter, but without the heating element)? I'd like to be able to charge my iPod and cell phone on long rides (while the engine is running)
My thoughts would be to wire it directly to the battery terminals, since the battery acts like a voltage sink of sorts.
Anyone do it any other way? I don't mind if the phone/iPod would need to remain under the seat to be charged, I should be able to run a headphone extension out from underneath the seat.
Thanks in advance!
Thanks in advance!
2000 ZRX 1100
1976 KZ 900- Daily Driver
- MFolks
Re: 12v Aux Output
01 Jul 2011 18:32
Which bike? I know on the Kz1000's/Kz1100's there is a set of fused wires for items like heated vests or gloves. They should be marked on your bikes wiring diagram as aux circuits or something like it.
- mtbspeedfreak
Re: 12v Aux Output
01 Jul 2011 18:41
'76 KZ900A4
2000 ZRX 1100
- loudhvx
Re: 12v Aux Output
02 Jul 2011 13:09 - 02 Jul 2011 13:11
Some KZ's had an aux output (spade-connector), but looking at your wiring diagram, it doesn't look like yours has it.
Wiring it to the battery should be fine. Make sure you get one with an inline fuse holder, and make sure no bare wiring can touch anything.
Also, obviously, leaving something charging permanently will kill the battery eventually. You just have to remember to unplug it when you are not running.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 02 Jul 2011 13:11 by loudhvx.
- djturnz
Re: 12v Aux Output
06 Jul 2011 15:26Remember, this means unplug the charger too, not just the phone.loudhvx wrote:
1982 KZ750 (4) LTD
- mtbspeedfreak
Re: 12v Aux Output
06 Jul 2011 16:05
Yep. I can leave the charger wired in though, correct? I'd just have to remove the 12v "cigarette charger" plug.
2000 ZRX 1100
- mark1122
- Keep twisting it
Re: 12v Aux Output
10 Jul 2011 18:17 - 29 Jan 2012 11:36
i saw a 750cc tripple at the bike night last week. he had the wire come right up to the bars, and a holder for his ipod on the bars.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Jan 2012 11:36 by mark1122.
- mtbspeedfreak
Re: 12v Aux Output
10 Jul 2011 18:27mark1122 wrote: i saw a 750cc tripple at the bike night last week. he had the wire come right up to the bars, and a hold for his ipod on the bars.
Haha. That's an anachronism if I've ever seen an anachronism.
2000 ZRX 1100
- mark1122
- Keep twisting it
Re: 12v Aux Output
10 Jul 2011 18:31mtbspeedfreak wrote:mark1122 wrote: i saw a 750cc tripple at the bike night last week. he had the wire come right up to the bars, and a hold for his ipod on the bars.
yea but we gotta keep up with the times. lol
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Jeff.Saunders
Re: 12v Aux Output
10 Jul 2011 20:05
You have to be careful to not overload the charging system. The Z1/KZ900 charging system is boardline if you are running with lights on all the time. Even 5w-10w additional draw can be a problem where you run the battery down.
www.z1enterprises.com
Z1 Ent on Facebook,
- mtbspeedfreak
Re: 12v Aux Output
27 Jul 2011 14:15
To determine the right fuse, I'll have to look at my chargers (in milliamps). Since I don't want it drawing more than 5 amps, I can stick a 5 amp fuse in (which will be overkill, the chargers will not draw more than 5 amps, if they did, I'd draw the battery down, I know
)- is this the correct logic?
(Thanks, I'm not all that familiar with electronics at this point.... getting there with your help!)
2000 ZRX 1100
