No spark at the POINTS??
- bgmrc
18 Jan 2011 13:50 - 19 Jan 2011 07:00
I HAVE A 79 KZ750B4 IM TURNING INTO A CAFE'
IM HAVING SOME ELECTRIC ISSUES...
MAIN ONES are NO SPARK AT THE POINTS??
WHAT IS BAD THAT LEADS TO THIS...I CHECKED FOR POWER AT THE 2 WIRES COMING OUT OF THE COIL..2 YELLOW ONES ...
THATS ALL I WAS ABLE TO GET TO SO FAR..
ALSO NOTHING HAPPENS WHEN THE STARTER BUTTON IS PUSHED...BUT I DO GET THE STARTER TO TURN WHEN I JUST THE SYLINOIDE(sp)
OTHER ELECTRIC ISSUES ALSO....BUT I WANT TO SEE IF THIS MOROT WILL RUN OR NOT
sorry for the CAPS!!!
I have the manual i downloaded from someone around here
anyone
Thanx
anyone
Thanx
Last edit: 19 Jan 2011 07:00 by bgmrc.
- bgmrc
- stonemaster
Re: No spark at the POINTS??
19 Jan 2011 07:31
u gotta be more specific, do u have lights, chek the fuse, etc,etc battery check ???, more info will get u more help, there are also troublshooting guides in most manuals
- Tony
Author
19 Jan 2011 08:30 - 19 Jan 2011 08:35
To address the "no spark at the points" problem. There should not be spark at the points. If there is you probably have a faulty condenser. If there is spark at the points they will erode and fail prematurely.
I did a quick google search and came up with this explanation. click here to learn how a points ignition system works.
Your manual has a section on your ignition system.
Last edit: 19 Jan 2011 08:35 by Tony.
- bgmrc
19 Jan 2011 08:54
had lights and all...
i was told there should be a lil spark seen at the points...so i was askin what i should check on the bike ...
i have read the manual and will do some of the info found in there..
was lookin to see if anyone knew of this issue
- stonemaster
19 Jan 2011 09:35 - 19 Jan 2011 09:39
there is visible electric charge in the points gap when it opens, whether u call it "spark " or not, whatever, ur link puts it at 250 volts upon opening, HES NOT GET ELECTRICITY TO POINTS
u say u HAD lights ??/start at battery and work ur way out loose ground from batt to frame maybe, check fuse , positive cable from batt??? start simple
Last edit: 19 Jan 2011 09:39 by stonemaster.
- bgmrc
19 Jan 2011 10:00
^^ thank you....
my info was from an my pop and he is an oldschool auto guy...so i figured it worked the same as a car and i would see a lil somethin...
so im gonna start with the fuses and whatnot...they look ok but im sure that could be false..
thanx for input!!
thanx for input!!
- bgmrc
19 Jan 2011 10:02
i fixed the ground already....
and yes had all the lights goin for a bit there...then i screwed my self useing break clean on the plastic clips...melted them...have to redo 2 of them...
- hocbj23
19 Jan 2011 14:06
Just because fuses look ok doesnt mean they are.Cheap to replace all the fuses in the box.Old fuses can corrode on the inside,look ok and still be shot.Ask me how I know this.Lol.bj
- bgmrc
19 Jan 2011 18:22 - 19 Jan 2011 18:27
agreed!!
im on it!
gonna start there and then fix the 2 connectors i melted with break clean spray...DONT USE IT TO CLEAN THE CONNECTIONS....ask me how i kow that!!! haaaa
make sure all lights are working again...
then go to the start/stop and ignition switches
then check for voltage at points
and then just incase look for any voltage at the plug caps..
pretty sure that should do me...
i replaced 4 or so connections already and the harness looks in good shape....so i thought anyway
im on it!
Last edit: 19 Jan 2011 18:27 by bgmrc.
- bgmrc
20 Jan 2011 21:40
UPDATE
so i got all the lights back up and running ...properly i think...the blinkers are all full time....is that a running light?? should they be always on? and they dont blink...but that could be the switch...
fixed the fuses...i still need 2 10 amps to go with the 20 amp thats in there...tuff to read the oether 2..so im not sure if they are 10's
i still have not voltage at the coil or points...no spark that i can see??
i have gone thru most of the herness...but there is still more
i did totally goe threw the start stop...cleaned it all up and now is perfect....but didnt help...sux!
so im at the head light area to see that going on in there..? there a are a few cut and not connected wires..
and there is a few on the harness just wrapped together...i see the P/O has tape on alot of stuff as he must of been going thru it also..
so there is nothing on that electric area by the fuses that will cause my problem?? could some there be bad?
and how do the point get there power?? i see nothing going to them....just comin from them to the coil is it...what supplies the points with power?
could the condencer/capacitor be the issue...i know that is supposed to regulate the voltage when it opens...could it stop a spark or power for that area?
ill be doing more work on it tomorrow night...
what could be in the ignition that might be an issue if i see all lights? and the connector plug...the big one for it looks great..no crud..
Thanx for any info
Marc
Thanx for any info
Marc
- stonemaster
21 Jan 2011 03:11 - 21 Jan 2011 03:19
well all ur accessories work, thats a start,
does the starter turn over when u hit the button ??
if no the check power to starter button
if yes disconnect wires to points, check them for continuity
could be a pinched wire, happened to me once
redo all badly done connections NOW
then proceed with testing
the fuses are color coded if u cant see the numbers, replace all
no power to points automatically means now power to coil as points control/operate coils
flasher probably bad on signals
save that for last
good luck
save that for last
good luck
Last edit: 21 Jan 2011 03:19 by stonemaster.
