  • Page:
  • 1
fuel booster 21 Dec 2023 12:06 #892990
  • david richard
  • david richard's Avatar Topic Author
  • Thank you received: 17
hi i am looking for a fuel octane booster i can use toto add to e 5 fuel after i have removed the ethonol ,until this september we had 0 per cent but no more i im not bothered about fuel preservative as i drain out all petrol over the winter any help before i spend hours looking for the right stuff thanks
fuel booster 21 Dec 2023 12:41 #892993
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 684
You'll be fighting a losing battle removing the ethanol. The percentage is only going one way. Ethanol, in itself, is not the problem, if anything it's an octane boost. The problem is its absorption of water from the atmosphere which creates an acidic mixture that attacks everything.
The easiest, most cost effective and viable solution is to encapsulate the ethanol molecules so they don't absorb moisture. This is what an ethanol treatment does. General treatments for road vehicles is effective for about six months as its assumed it'll get used in that time frame. The treatment available for marine engines has a far greater longetivity as boats may not be used for far greater periods.
Personally I use stabil 360 marine and haven't experienced any issues even with fuel that's been left in the bike for a couple of years.
Z1000J2 somewhat modified!
The following user(s) said Thank You: Nessism, sf4t7, Dragbike_Mike, david richard
Last edit: by Warren3200gt.
fuel booster 21 Dec 2023 15:07 #892996
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1991
Starbrite HD Marine      thru amazon , walmart  and others
fuel booster 21 Dec 2023 16:15 #892997
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
i'VE ONLY BEEN TALKING ABOUT MARVELS mYSTERY oIL ON THIS SITE SINCE 2004.
SORRY TO LAZY TO FIX THE TEXT!
Marty in Buffalo
fuel booster 21 Dec 2023 16:23 #892998
  • z1kzonly
  • z1kzonly's Avatar
Hello Warren,  What is your Red Bike in picture? Year? Model?
I have a set of the brake rotors same as on your bike.
I am going to sell them after I clean them up.
The minimum thickness is 4.5mm Ones I have are at, .199" or 5.05mm.
When I find a crap Z1 disc to grid down. I'll clean these 2 up. Bug my friend to do the work.
Marty in Buffalo
fuel booster 21 Dec 2023 22:17 #893002
  • Warren3200gt
Marty in Buffalo
Hi Marty,
Majority of it is a Z1000J2 1982 but with Gpz1100 top end and forks, wheels, brakes etc due to having been involved in a front end accident.
Came to me having been completely dismantled 40 odd years ago.
fuel booster 22 Dec 2023 04:35 #893004
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1043
Marty in Buffalo
I think I may have one Marty.  I'll check later today.
Last edit: by hardrockminer.
  • Page:
  • 1
