what to do ?
- zirafin
Re: what to do ?
17 May 2016 06:01
now i nead info ;(
it looks like cam timing is lost and i dont know maybe fire time is bad to
so first i turn engine til TOP DEAD CENTER (TDC) on mark T I F on red mark
then i fixs ex cam ,then zi5 mark on cam , then valve cover, tensioner installed .
after is still not working and does not accept the throttle
maybe is chain was over jumped , but if i loosed cams and i readjusted them. its should work.
new coils. carburetor is clean. compression is its poping of finger .and still 4 cylinder is not hot like other 1.2.3.
- loudhvx
Re: what to do ?
17 May 2016 10:10
Alright, let's start with cam timing since that is a question. (The tensioner housing was broken and repaired somewhere near the beginning of this thread.)
Check the timing again, like on the drawing you posted from my website. (I'll repost it.) In order for the camshaft marks to line up, you must press down on the chain in the middle, like the drawing shows. But make sure the tensioner cap is off and the crosswedge is loose before doing that. Try to post some photos so we can confirm.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- zirafin
Re: what to do ?
18 May 2016 01:40
halo here is all pictures. and video
1, i rotate on mark TIF
2. fixed ex and e/5
3. valve cover new gasket
4. tensioner
5. after starting is same and now its not working cylinder 4 its cold . u can look in video
2. fixed ex and e/5
4. tensioner
Attachment IMAG1383.jpg not found
Attachment IMAG1384.jpg not found
Attachment IMAG1385.jpg not found
Attachment IMAG1387.jpg not found
Attachment IMAG1389.jpg not found
Attachment IMAG1394.jpg not found
Attachment IMAG1395.jpg not found
Attachment IMAG1396.jpg not found
- zirafin
Re: what to do ?
18 May 2016 01:49 - 18 May 2016 01:51
bad sound ore now sound
video :
and video after i start the engine.and u hear through the carburettor fired back small noises :
video :
Last edit: 18 May 2016 01:51 by zirafin.
Re: what to do ?
18 May 2016 07:12
Does it get hot when you rev it? Pics of plugs?
- loudhvx
Re: what to do ?
18 May 2016 07:37 - 18 May 2016 07:50
The cam timing looks good, as long as the pin count is correct.
And yes, the arrow on the #8 cap should point forward like the other caps.
So it is definitely #4 cylinder not working. Did you double-check the valve clearance while you had the cover off? What were the clearances?
It would be best to rule out the engine before moving to the carbs (ignition coils already replaced).
So you may have to get a compression tester.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 18 May 2016 07:50 by loudhvx.
- zirafin
Re: what to do ?
18 May 2016 11:15
hi again
i did not check the valve clearance. i can try tomorrow ,its only i start to be very tired of taking off the valve cover ......
and maybe i will find tool for testing the compression .i thing it will be the problem because i can find why its not working..
thanks for help and can u write info for valve clearance checking ,in manual i jus find how to test ,but how many millimeters is ok and what is bad.
and next weak i try to show my kz550 to mechanic in other city. i hope he can help to .
thanks again .i am hopples
but i try i want to ride on this nice kawa
- zirafin
Re: what to do ?
19 May 2016 00:39
sp i buy compression testing tool spend 19 euro . and all cylinder is :
cold :
1-125/9
2-125/9
3-120-125/9
4-125-140/9-12
warm up engine
1-125
2-125
3-125
4-125
cold :
1-125/9
2-125/9
3-120-125/9
4-125-140/9-12
warm up engine
1-125
2-125
3-125
4-125
Attachment IMAG1403.jpg not found
Attachment IMAG1402.jpg not found
Attachment IMAG1408.jpg not found
Attachment IMAG1406.jpg not found
- zirafin
Re: what to do ?
19 May 2016 00:41
and i tace out spark plugs it was interest why 3 cylinder spark plug is bend its all same spark plugs.
- zirafin
- KZB2 650
Re: what to do ?
19 May 2016 05:06
Make sure you have the right plugs (not familiar with your year) ..... and the gap looks to be too wide on the 1 and 2 plugs then too tight on the 3 and 4.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- The_Proletariat
- "Cocaine is a hell of a drug"
Re: what to do ?
19 May 2016 06:44 - 19 May 2016 06:52
Those are the correct plugs but they should be replaced.
There are many guides for checking valve clearance. The most recent:
www.kzrider.com/forum/2-engine/602260-ho...earance?limitstart=0
You need feeler gauges.
On plug #3, is the ground electrode contacting the center electrode? If so, that is your dead cylinder.
Attachment valve.png not found
1982 Kawasaki KZ550 LTD
Last edit: 19 May 2016 06:52 by The_Proletariat.
