Mikuni VM 33 Carbs
02 Jan 2017 11:15 #751165 by JOE MKII
Replied by JOE MKII on topic Mikuni VM 33 Carbs
Semi hi-jack maybe :ohmy:
They seem to sell quickly on flea bay for around $300.00 give or take.
They were once THE carbs to use, many moons ago…..
I believe its called "Oppositional Defiance Disorder"
  • SWest
  • Topic Author
  • 10 22 2014
02 Jan 2017 12:02 #751169 by SWest
Replied by SWest on topic Mikuni VM 33 Carbs
Jonny wrote: I hope I am not highjacking here, but I am curious about whether or not there is much of a market for VM33's. I've read through this whole thread, and get the feel that at least Steve is having success with them.
I mainly ask because I seem to have inherited a set with a parts 650 I picked up a couple of months ago. As soon as I can get it organized, I will post some photos, to confirm what they are. I reckon somebody else can let me know if I have it wrong anyway.
The plan had been just to tidy them up for sale, as they are far too big for any of my bikes, and it seems they have some intrinsic value. If the OP was suggesting they can be worth $250-300 USD, then it is worth the time to clean them up and sell them off. (Or, as always for fair prize to a fellow KZer.)
Pics soon,
Cheers,
Jon
I don't mind. Put up some pics before you spend any money on them. B)
02 Jan 2017 14:40 - 02 Jan 2017 14:41 #751182 by Jonny
Replied by Jonny on topic Mikuni VM 33 Carbs
Thanks all for helping with the identification.
The photos aren't great, as they are just off my cell phone, but I think they are at least sufficiently good to figure out what these are.
They've clearly been modified for vacuum ports by somebody, which among a couple other things suggested to me that they were maybe the VM33s, which as per earlier did not come with synching ports. I did check the bore diameter quickly at the fellows house, and I seem to remember it being a touch OVER 33mm, but not an awful lot. I currently have then soaking in some hot soapy water to clean them up at least a little before moving on.
If this isn't enough info for a good identification, then let me know, and I can take some more photos or look for other distinguishing marks.
Thanks in advance,
Jon
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
Last edit: 02 Jan 2017 14:41 by Jonny.
  • SWest
  • Topic Author
  • 10 22 2014
02 Jan 2017 15:15 #751183 by SWest
02 Jan 2017 17:48 #751215 by Jonny
Great,
Thanks Steve. Appreciate the confirmation. I guess I will give them a little bit of love and a good clean up and sell 'em off to someone who can put them to good use.
Cheers!
'78 KZ 650C2 'Lila'
03 Jan 2017 17:12 - 03 Jan 2017 17:14 #751324 by zukdave
Replied by zukdave on topic Mikuni VM 33 Carbs
To id Mikuni carbs there is a number stamped on the bolt flange in front of the choke lever
on the number one carb (left side sitting on bike).
Jonny I may be up for those VM33's what kind of bucks if you don't touch them and sell as is.
Not doubting your ability but first thing I'll do is break them down for a few hour ride in the sonic cleaner
no sense you doing it then me do my thing with them
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 03 Jan 2017 17:14 by zukdave.
04 Jan 2017 09:00 #751364 by Jonny
PM sent Dave!
'78 KZ 650C2 'Lila'
  • SWest
  • Topic Author
  • 10 22 2014
26 Jan 2017 18:45 #752973 by SWest
AFTERMARKET PETCOCK
Rather than starting another thread I thought I'd put it here. It appears the port going to the sediment bowl is smaller than the inlet tubes. I've always suspected the big carbs were starving for fuel at WOT or high speed riding. Didn't have that problem with the stock one. The 33's have two feed lines and a common galley connecting all four carbs. The needle seats are large with strainer screens on each one. The port might be my next mod. :whistle:
  • SWest
  • Topic Author
  • 10 22 2014
26 Apr 2017 13:48 - 27 Apr 2017 06:18 #760315 by SWest
Trying to get the pilot air screws to work.
Revised clip below.
Last edit: 27 Apr 2017 06:18 by SWest.
  • daveo
  • Premium Member
  • Premium Member
26 Apr 2017 19:16 #760337 by daveo
Replied by daveo on topic Mikuni VM 33 Carbs
SWest wrote: Trying to get the pilot air screws to work.
What size are the air screws you have in there?
1982 KZ1100-A2 (1170cc sleeper 🫣)
  • SWest
  • Topic Author
  • 10 22 2014
26 Apr 2017 19:23 #760338 by SWest
I don't understand. I got them from jetsRus
  • daveo
  • Premium Member
  • Premium Member
26 Apr 2017 19:41 - 26 Apr 2017 19:51 #760340 by daveo
Sorry, got the screw mixed up with the air jet :blink:
Maybe it doesn't matter, but observing the Jets R Us "Air Jet Chart", it shows various sizes available with the BS30/97 1.2 standard specification Pilot Air Jet for the KZ1000/1100
Check out the chart below the exploded view and red highlight over Standard Jetting Specifications VM33 Smoothbore
www.jetsrus.com/carburetor/carb_mikuni_V...oded_view_parts.html
Last edit: 26 Apr 2017 19:51 by daveo.
