  • Page:
  • 1
KZ440 Air filter case problem 28 Nov 2015 02:33 #700867
  • BornAgainBiker
  • BornAgainBiker's Avatar Topic Author
  • Thank you received: 3
Would anyone know of a good fix for a worn out seal on the air filter case for a KZ440? Here is a photo of the part:
Attachment DSC_0313.jpg not found
All the best, Jeff
1984 KZ440 D6
KZ440 Air filter case problem 28 Nov 2015 02:52 #700868
  • davido
  • davido's Avatar
  • Thank you received: 286
If youre talking about the foam strip around the edge,you could probably just clean it off and put a new one on. You can buy it at any hardware shop.Its used for sealing widows and doors and its very cheap.
If youre talking about something else,then,sorry,I dont know.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: BornAgainBiker
KZ440 Air filter case problem 28 Nov 2015 02:53 #700869
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
clean it off and apply some closed cell foam insulation. You can get it at the hardware store. You may need to use additional adhesive..
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
KZ440 Air filter case problem 28 Nov 2015 03:06 #700871
  • BornAgainBiker
Thanks Guys,
I thought that that type of fix might work, but wasn't sure. :)
All the best, Jeff
1984 KZ440 D6
  • Page:
  • 1
