Persistent flat spot off idle 25 Nov 2015 10:07 #700491
  • McZed
  • McZed's Avatar
  • Thank you received: 12
Are you certain your ignition timing is set correctly? It may not be the carbs.
Persistent flat spot off idle 25 Nov 2015 10:21 #700492
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
Timing advancer working right?
Persistent flat spot off idle 25 Nov 2015 12:44 #700518
  • jackleberry
  • jackleberry's Avatar Topic Author
  • Thank you received: 56
McZed wrote: Are you certain your ignition timing is set correctly? It may not be the carbs.
Ignition timing is not adjustable on these bikes.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Persistent flat spot off idle 25 Nov 2015 12:46 #700519
  • jackleberry
bountyhunter wrote: Timing advancer working right?
Yeah, seems to be working right. All lubed up. No problems at 4K RPM... No pinging when lugging the engine on the highway.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Persistent flat spot off idle 03 Dec 2015 13:00 #701751
  • Copbike1000
  • Copbike1000's Avatar
  • Thank you received: 8
Had same issues with my bike. I messed with mixture screws until I could not see straight. I must have taken the carbs off and reinstalled 10 times. I was able to get the bike to idle better but It would not run 100% until I hit 3k rpm. I finally dove deeper into the carbs and found that the pilot jets were all gummed up and, that was after major cleaning of carbs. Passages on pilot jets are tiny. I went ahead and bought a new set, installed and FINALLY got it right!!!
I have discovered that if your bike sits un-ridden too long, you risk the chance of clogging the pilot jets. Good luck.
1994 Kawasaki KZ1000P, Rancho Cordova, Ca
www.kzrider.com/forum/11-projects/598384...-project-bike#674472
Persistent flat spot off idle 03 Dec 2015 16:39 #701783
  • Mean Green Z28
  • Mean Green Z28's Avatar
  • Kawasaki NooB
I am very new to this but one passage/opening I found clogged on my carbs was the pilot bypass orifices near the throttle blade. Idle was fine and mid/top range was fine, the off idle fueling was f'd up, and it turned out that these tiny little orifices were clogged.
they're shown here as transfer ports
www.xs650.com/forum/showpost.php?s=2464b...7&p=4464&postcount=2
2010 Camaro 2SS
1983 Kawi KZ1000P ... bag of bolts
The following user(s) said Thank You: 750Kruzer
Last edit: by Mean Green Z28.
Persistent flat spot off idle 03 Dec 2015 18:15 #701798
  • Copbike1000
Mean Green Z28, Thanks for link to carb diagram......
Persistent flat spot off idle 04 Dec 2015 06:18 #701855
  • jackleberry
Mean Green Z28 wrote: I am very new to this but one passage/opening I found clogged on my carbs was the pilot bypass orifices near the throttle blade. Idle was fine and mid/top range was fine, the off idle fueling was f'd up, and it turned out that these tiny little orifices were clogged.
That's possible. I know the pilot jets themselves are clean because I've had them out many times. I've blasted that entire circuit with carb cleaner many times and seen it exit via those holes. How did you know yours were clogged and how did you unclog them?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Persistent flat spot off idle 04 Dec 2015 06:42 #701862
  • jackleberry
Copbike1000 wrote: Had same issues with my bike. I messed with mixture screws until I could not see straight. I must have taken the carbs off and reinstalled 10 times. I was able to get the bike to idle better but It would not run 100% until I hit 3k rpm. I finally dove deeper into the carbs and found that the pilot jets were all gummed up and, that was after major cleaning of carbs. Passages on pilot jets are tiny. I went ahead and bought a new set, installed and FINALLY got it right!!!
Yeah, that's where I am right now. This bike did sit for 2 years before I got it. The carbs weren't nearly as gummed up as I expected (PO had dumped a lot of sta-bil in the tank and idled the motor every month), but there was some crud in there, especially under the pilot jets. However, I've cleaned them so many times now... I started this thread in the hopes that someone would chime in telling me there's some super-secret hidden accelerator pump or something on the BS34's that I need to clean too. The fact that it's such a subtle thing doesn't help either...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Persistent flat spot off idle 04 Dec 2015 19:09 #701988
  • bountyhunter
You might try draining the bowls and reinstalling the bowl screws then filling the carbs with Gumout liquid or some equally strong carb cleaner and let sit for a week. If internals have oxidized gas gumming them up, that should clear it.
Persistent flat spot off idle 05 Dec 2015 04:50 #701997
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
Pics would help. Guitar string through the pilots?
Persistent flat spot off idle 05 Dec 2015 14:27 #702046
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
When no amount of jetting cures a problem it's a good indication the fuel level is not correct.
Larry C.
