  • Page:
  • 1
  • 2
Cylinders 1&2 not firing - Fuel Problem 12 Oct 2015 15:01 #694316
  • TomasDouglas
  • TomasDouglas's Avatar Topic Author
  • Thank you received: 0
I finally got the carbs installed on the 1980 KZ550 that I have rebuilt and started the bike and it finally ran and I got it to idle. I was thrilled and cranked the throttle however it was sluggish and I noticed that cylinders 1 & 2 are not firing while 3 & 4 are firing. The 3 & 4 right exhaust pipes get hot the 1 & 2 left side do not.
Cylinders 1 & 2 have good compression 125 and 130, and are getting spark. When I rebuilt it I put in new coils, new ignition kit, new spark plugs, new plug wires. I also checked the valve clearances and replaced shims so that all the clearances were according to spec.
I soaked and cleaned the carbs, took the float bowls off, soldered cracks in 2 of the overflow tubes, cleaned the pilot and main jets, the float valve seat and float valve needle, and set the float levels on the bench and on the bike when I finally got them installed.
It looks to me like the 1 & 2 cylinders are not getting fuel so I must have missed something when I cleaned the carbs. My next step is to take the carbs off and try to figure out what I missed cleaning or might need to replace.
I would appreciate getting any opinions, or comments or help trying to figure out my problem.
This is a picture of the spark plugs 1 & 2 are black 3 & 4 are white.
Attachment IMG_01502.jpg not found
Tomas Douglas
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
Cylinders 1&2 not firing - Fuel Problem 12 Oct 2015 18:41 #694355
  • Barry2
  • Barry2's Avatar
  • Thank you received: 23
Are you sure you have the plug wires on the right plugs?
1976 KZ900
Last edit: by Barry2.
Cylinders 1&2 not firing - Fuel Problem 12 Oct 2015 19:14 #694359
  • TomasDouglas
Yes right coil wires to 1 & 4, left coil wires to 2 & 3.
Tomas
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
Last edit: by TomasDouglas. Reason: dyslexia
Cylinders 1&2 not firing - Fuel Problem 12 Oct 2015 20:52 #694363
  • Barry2
  • Barry2's Avatar
Got the correct hose connected to the fuel shut off valve?
1976 KZ900
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 02:33 #694368
  • Grnole
  • Grnole's Avatar
  • Thank you received: 8
did 1 and 2 fire prior? How is your fuel delivery? You could try the clear tube test with the carbs on the bike to insure your bowls are filling up from the petcock and fuel inlet lines.
1980 KZ1000 LTD -B4
1984 Yamaha FJ1100
1972 Honda CL350 (sold)
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 02:44 #694371
  • undiablo
  • undiablo's Avatar
  • Thank you received: 64
Idle mixture screw are all equal?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 03:22 #694373
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
Check the common vent between the two carbs.
kzrider.com/forum/3-carburetor/597187-critters#661716
The following user(s) said Thank You: TomasDouglas
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 05:15 #694391
  • redhawk4
  • redhawk4's Avatar
Take the float bowl screws out on the carbs of those cylinders not firing to check you are getting fuel into those carbs. perhaps the floats are stuck closed or something is blocking the transfer of fuel to the carbs on the cylinders that are not firing.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 05:20 #694393
  • SWest
  • SWest's Avatar
  • 10 22 2014
Petcock strainer too.
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 17:45 #694481
  • TomasDouglas
This is a picture of the mower tank that I used when I bench tested float levels, I used the same set up after installing the carbs on the bike and the bowls were all getting gas.
Attachment IMG_01292.jpg not found
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 17:49 #694482
  • TomasDouglas
No this is the first time I have started the bike I am at the final stage of the rebuild. I am using a mower tank on a stand for fuel see the picture below. All the carbs are getting fuel but it isn't getting into the 1 & 2 cylinders.
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
Cylinders 1&2 not firing - Fuel Problem 13 Oct 2015 17:55 #694485
  • Thank you received: 2829
If you can start the bike, or even if you can only crank it with the starter, when you put your hand over the intake throat of # 1 and #2 can you feel vacuum? Ed
  • Page:
  • 1
  • 2
