  • Page:
  • 1
Ultrasonic carb cleaning help? 29 Jun 2015 14:00 #678739
  • K.D. HART
  • K.D. HART's Avatar Topic Author
  • Thank you received: 11
I picked up a used Model #4 Branson 8200 ultrasonic cleaner to clean my carbs and other parts with and was told I could use a 2 parts simple green to 2 parts distilled water. I did a test on a old set of carbs, but it tarnished the bodies black.
Does anyone know a ultrasonic cleaner solution to use for carbs/aluminum??? Not interested in anymore home mixtures.
Ultrasonic carb cleaning help? 29 Jun 2015 14:17 #678744
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
  • Thank you received: 36
Yeah that's happened before a few times with Simple Green. Be careful.
I've heard great things about Pinesol.
2000 ZRX 1100
1976 KZ 900- Daily Driver
Ultrasonic carb cleaning help? 29 Jun 2015 14:50 #678747
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
I've had good luck with Berryman's Chemtool
Ultrasonic carb cleaning help? 29 Jun 2015 14:55 #678748
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Pine sol turned my two sets of 26mm carbs a sickening dark charcoal grey/black too.
Berryman's didn't do diddly squat and a complete waste of money.
The thing that worked was an hour and half with 2lbs of baking soda at 7cfm and 90psi.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: by missionkz.
Ultrasonic carb cleaning help? 29 Jun 2015 16:32 #678764
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
I use a sonic cleaner every day all day at work with a
25-75 mix simple green and tap water and have never
had an issue with carbs turning black
About 30 min. at 150 degree's seems to work just fine for me..
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Ultrasonic carb cleaning help? 30 Jun 2015 06:44 #678824
  • K.D. HART
Does anyone know a ultrasonic cleaner solution to use for carbs/aluminum??? (Store bought solution for cleaner)
As I said in my first post. I'm not looking for anymore home mixtures.
Ultrasonic carb cleaning help? 30 Jun 2015 13:26 #678857
  • Spencer440
  • Spencer440's Avatar
  • Thank you received: 8
1980 KZ440-B
1979 Kawasaki KZ650-C3
The following user(s) said Thank You: K.D. HART
Ultrasonic carb cleaning help? 30 Jun 2015 15:09 #678861
  • etbike3135
  • etbike3135's Avatar
  • Thank you received: 50
1220 is all I've found to work
1973 Kawasaki Z1
18 years in dragbikes
Ultrasonic carb cleaning help? 01 Jul 2015 07:38 #678944
  • K.D. HART
Thanks for the heads up on the 1220 guys! :)
I seen that in my searches yesterday. I also contacted Branson to see if they had a cleaner that was safe to use on aluminum carbs to remove varnish/crud and oil. I'll copy and paste the reply I received.
Kenny,
Branson Ultrasonics referred your inquiry to my company for follow-up. We are a distributor of their products.
Branson's MC-3 is safe to use on aluminum. Attached is a product bulletin. Also, following is s link to our website for part numbers and pricing information:
www.proequip.com/ultrasonic-cleaning-chemicals/ (scroll down to see the MC-3 information)
www.tedpella.com/technote_html/17365,%2017365-1%20TN.pdf
Please feel free to contact me if I can be of further assistance.
Best Regards,
Rob Deckelman
Process Equipment & Supply, Inc.
31255 Lorain Road
Cleveland, Ohio 44070
Tel: 800-539-6336
Fax: 800-539-6371
Email: This email address is being protected from spambots. You need JavaScript enabled to view it.
www.proequip.com
Last edit: by K.D. HART.
  • Page:
  • 1
