  • Page:
  • 1
  • 2
Mikuni smoothbores 24 Feb 2015 21:47 #662693
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
Got a pic?
Mikuni smoothbores 25 Feb 2015 08:17 #662725
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
Last edit: by 531blackbanshee.
Mikuni smoothbores 25 Feb 2015 10:17 #662738
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
Motion pro makes an adjustable throttle for drag racing that will go to WOT in a 1/4 turn. They also have one that has swappable cams so you can adjust how quickly it goes to WOT, I.E., 1/4 OR 1/2 turn.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Mikuni smoothbores 25 Feb 2015 12:15 #662750
  • Thank you received: 2829
I used a quick throttle for several years on my BSA, but got rid of it. The problem was bumps or potholes. When I would hit one that I was not totally prepared for I would find the front wheel of the bike shooting skyward because the slightest twitch on the throttle would open the carbs wide open. Depending on the road and the amount of traffic that can get your heart pumping! If you put one on the bike be aware of that issue. ;) Ed
Mikuni smoothbores 26 Feb 2015 16:47 #662829
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
I've ran a cheap Motion Pro single cable 1/4 turn
with a light return spring with my VM29's for about
two years and love it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Mikuni smoothbores 26 Feb 2015 17:58 #662840
  • kaw-a-holic
650ed wrote: I used a quick throttle for several years on my BSA, but got rid of it. The problem was bumps or potholes. When I would hit one that I was not totally prepared for I would find the front wheel of the bike shooting skyward because the slightest twitch on the throttle would open the carbs wide open. Depending on the road and the amount of traffic that can get your heart pumping! If you put one on the bike be aware of that issue. ;) Ed
If I were using the bike for street and strip, I would go with the one with interchangeable cams. This is the one I was referring to: www.motosport.com/motion-pro-revolver-throttle-kit
Jon
1977 KZ1000a1
Mesa, AZ
Mikuni smoothbores 01 Mar 2015 15:12 #663095
  • jerry a smith
  • jerry a smith's Avatar Topic Author
  • Thank you received: 3
I ordered a Venhill throttle.I'm familiar with excessive throttle response on a road bike.I had a '71 650 Yamaha(new) and it had the same sensitivity,but on a race bike it's all about throttle response in the corners.I'll let you know how it works.I think some of the sticky throttle return could be to do with a 35 year old throttle assembly even though I've had it apart numerous times.
Jerry
Mikuni smoothbores 01 Mar 2015 19:56 #663120
  • Thank you received: 2098
BlackZ1R wrote: ... Don't overtighten the small screws in the bottom of the carb in the bowl area....
Would heed this important advice from BlackZ1R.
As I recall, there's a small locator screw into the bottom of each jet block that keeps the jet block orientated in its correct position inside the carb bore. The screw is not centered, and if overtightened can skew the jet block enough out of position to cause the throttle slide to rub against the jet block.
Good Fortune! :)
Mikuni smoothbores 03 Mar 2015 13:34 #663342
  • jerry a smith
When I install the new throttle I'll check the screws.Thanks.
Mikuni smoothbores 09 Mar 2015 17:19 #663904
  • mcmurray
  • mcmurray's Avatar
  • Thank you received: 0
Anyone know where I can find the exact rebuild kit for these? I tried a bunch.....I don't find them....Thanks
Mikuni smoothbores 09 Mar 2015 17:22 #663906
  • mcmurray
  • mcmurray's Avatar
The above carbs are on this bike.
Mikuni smoothbores 09 Mar 2015 18:47 #663916
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
  • Thank you received: 47
Those are 33mm smooth bores. You most likely won't find a rebuild kit for them. It's possible to find individual parts for them through Z1 Enterprises and ebay vendors. You're looking are bowl gaskets, top cover gaskets, fuel tube O-rings, enrichener O-rings, air screw o-rings, and needles and seats. New jets from Sudco, or Z1 Entp.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
The following user(s) said Thank You: mcmurray
  • Page:
  • 1
  • 2
