carb issues? 20 Jun 2015 12:10 #677454
  • Special KK
  • Special KK's Avatar Topic Author
  • Thank you received: 3
ok thanks, i greased the worm drive unit the other day seemed ok though.
2008 Aprilia Shiver SL750
1983 Kawasaki KZ750 LTD H4 Four cylinder
Previous bikes:
1999 Honda CBR 600 fx
1992 Kawasaki Zephyr 550b
1990 Honda CG 125
"All work and no play makes jack a dull boy"
carb issues? 24 Jun 2015 09:33 #678098
  • Special KK
Took some photos of my clutch before i put it back together with new gasket. I gave the friction plates a roughing up with some 800 grit paper and took it out for a ride, made absolutely no difference. Still think it could be clutch though because its difficult to engage second gear whilst at standstill no matter how i adjust it, no problem whilst moving, and read somewhere that the bike should stall out if you try to pull away in a high gear, i put it in fifth and it still pulls away without stalling.
It does feel as though theres no power when you try to pull away in first though, Ive noticed it kind of overrevs a bit before it engages to go.
Anyway these are the pics of the plates, im not sure if they look ok? Dont look that bad to me but i dont have much experience with clutches.
Attachment IMG_20150624_150039363.jpg not found
Attachment IMG_20150624_150121241_HDR.jpg not found
Attachment IMG_20150624_150214415.jpg not found
Attachment IMG_20150624_150314210.jpg not found
Previous bikes:
1990 Honda CG 125
Last edit: by Special KK.
carb issues? 24 Jun 2015 14:45 #678121
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
They look fine. Cable or adjuster sticking is the only answer.
