KZ650 carb info 11 Nov 2014 01:35 #653346
  • Nateowens
  • Nateowens's Avatar Topic Author
  • Thank you received: 0
Hi all,
I'm After some info on carbs for a kz650
I recently bought another bike a kz650 I've started the restoration and found the carbs fItted were
Keihin cv type carbs with serial number TI29
are these suitable for this engine?
Any help would be appreciated
KZ650 carb info 11 Nov 2014 05:38 #653350
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
A photo would be helpful for identifying the carburetors.
The serial number probably won't be much help.
I'd guess they're from a 750-4. With the proper jetting, they'll probably work fine. ???
The 82-83 650-CSR came w Mikuni BS32 carburetors (CV type).
Last edit: by martin_csr.
KZ650 carb info 11 Nov 2014 06:38 #653355
  • Thank you received: 2829
Please post your bike's exact year & model in your signature line. There were a number of different carb types used on the various KZ650 models. Ed
KZ650 carb info 11 Nov 2014 15:08 #653387
  • Nateowens
I could be mistaken but I don't think these carbs are off a 650 or 750 KZ
that's why I supplied the serial number of the carbs as well
the engine number is KZ650BE1*****
the pics are from when I stripped them for cleaning
KZ650 carb info 11 Nov 2014 15:09 #653388
  • Nateowens
for some reason it wont let me upload the pics sorry
KZ650 carb info 11 Nov 2014 15:10 #653389
I'll try once more......
What year and model is the bike? Ed
KZ650 carb info 11 Nov 2014 15:13 #653390
  • Nateowens
ok.. the bike has had an engine swap its a 750 frame with a 650 engine in it
did you still want the frame number???
prob no good to you huh?
KZ650 carb info 11 Nov 2014 15:17 #653391
  • DSummerlin
  • DSummerlin's Avatar
  • Thank you received: 10
he's asking for the year of the bike. Do you know what year your bike is? What year is the motor, if it's swapped? These things matter.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
KZ650 carb info 11 Nov 2014 15:18 #653392
  • Nateowens
its a 1981 KZ750 E frame
KZ650 carb info 11 Nov 2014 15:19 #653393
No, the frame number won't help since it's a combination of different fame and engine. However, you still will need to know what model bike the engine came from as there are significant differences between the engines of the various years/models. Since you are reluctant to give the engine serial number (afraid it's stolen?) take a look at the link below to figure out what model KZ650 it is from. Ed
models.kz650.info/index.htm
KZ650 carb info 11 Nov 2014 15:21 #653394
  • Nateowens
im not sure of the build date of the engine
this is the way I purchased the bike and I don't have any info on it
KZ650 carb info 11 Nov 2014 15:24 #653395
Take a look at my posting above.
