  • Page:
  • 1
  • 2
confused with carbs 12 Oct 2014 08:37 #650463
  • Bama704
  • Bama704's Avatar Topic Author
  • Thank you received: 28
I have a 1977 kz900 frame # Z1F-514064, engine # Z1E135901. I am confused about my carbs though, i needed to buy some new gaskets so i purchased the ones I thought were for my carbs but when I got them, the top gasket has three holes for screws where as my carbs only have two screw holes. And the bottom gaskets are not squared, they are angled on one side. According to Z1 enterprises it looks like I have carbs from a 1973 Z1 28mm carbs? The ID is 28.6mm, Can anybody help me out with what my carbs are and the gaskets I will need?
1977 KZ900
Carbs are late model 1975 28mm
Re:confused with carbs 12 Oct 2014 09:00 #650464
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Thank you received: 117
Those carbs are definitely Z1 carbs but I don't know the little details that would determine if they were from '73, '74 or '75 though.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
The following user(s) said Thank You: Bama704
Re:confused with carbs 12 Oct 2014 09:12 #650465
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1623
I guess those are VM28 carburetors (WGcarbs.com Tech Stuff Index page).
From the diagrams at Partzilla the Z1 carb tops had 2 screws (73-75).
The stock KZ900 carbs had 3 screws.
Re:confused with carbs 12 Oct 2014 09:55 #650468
  • Bama704
Is it normal to have this kind of mismatch?
1977 KZ900
confused with carbs 12 Oct 2014 10:06 #650469
  • etbike3135
  • etbike3135's Avatar
  • Thank you received: 50
Those are 75 Z1 900 carbs. 28mm
1973 Kawasaki Z1
18 years in dragbikes
Re:confused with carbs 12 Oct 2014 14:51 #650493
  • moneypit
  • moneypit's Avatar
  • Thank you received: 35
Bama704 wrote: Is it normal to have this kind of mismatch?
PO changed them out from 26mm too 28mm, for better performance.
2-76 kz900
St Paul MN
Re:confused with carbs 13 Oct 2014 06:55 #650537
  • Bama704
Do yall know what the stock jet sizes would be for this carb?
1977 KZ900
Re:confused with carbs 13 Oct 2014 09:30 #650548
  • Bama704
In addition to anybody knowing the correct jet sizes, has anybody on this forum mounted up the 1975 Z1 Carbs to a 77 KZ900?
1977 KZ900
confused with carbs 13 Oct 2014 11:25 #650557
  • Arial Bender
  • Arial Bender's Avatar
Clymer manual.
78 Z1-R
confused with carbs 13 Oct 2014 11:28 #650558
  • Arial Bender
Page didn't load?
78 Z1-R
confused with carbs 14 Oct 2014 06:06 #650621
  • Bama704
I have a Hynes manual, it is for my 77 KZ900 but it doesn't cover the 1975 Z1 Carbs that I just found out I had. The page didn't load if you were trying to upload it from Clymer manual.
1977 KZ900
confused with carbs 14 Oct 2014 07:56 #650624
  • Arial Bender
main 112.5 pilot 17.5 needle jet 0-8.
Attachment Carbs001.jpg not found
78 Z1-R
Last edit: by Arial Bender. Reason: attachment
  • Page:
  • 1
  • 2
