  • Page:
  • 1
1980 choke linkage questions 10 Sep 2014 12:27 #647036
  • chonus
  • chonus's Avatar Topic Author
  • Thank you received: 8
hey, just bought a 1980 kz750 LTD. is the orange arrowed bit supposed to fit in the groove of the white arrowed bit? it wasnt when i got it. one was just resting on the other. and the return spring is all boogered up too, is that little spring supposed to close all 4 choke valves? or is the lever supposed to return it somehow. Am I missing something? Thanks in advance, I dont have a manual for this bike yet
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
1980 choke linkage questions 10 Sep 2014 17:26 #647072
  • chonus
Bump
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
1980 choke linkage questions 13 Sep 2014 20:37 #647447
  • gixxerkidd03
  • gixxerkidd03's Avatar
  • Thank you received: 3
here are some online manuals : kz.bike-night.com/manual.html
i dont have much advice on the choke spring. i ran into the same issue with mine and it was resolved by another person.
eric
1981 KZ750e
Re:1980 choke linkage questions 19 Sep 2014 20:56 #648123
  • koloj
  • koloj's Avatar
  • Thank you received: 5
The spring goes on the white arrow one the little Grove not big Grove when u pull the choke lever the spring should kick it back
1980 choke linkage questions 20 Sep 2014 06:04 #648142
  • LineArtist
  • LineArtist's Avatar
  • Thank you received: 35
Try finding the illustrated parts list/manual online. I found it more useful than the FSM when it comes to determine what goes where. Many of the online parts store use the old parts diagrams to identify parts for sale, so you can find info there too.
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
1980 choke linkage questions 20 Sep 2014 06:16 #648143
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
www.kawasaki.com/OwnerInfo/
On the right side of the screen, under Owner Info, choose Parts Diagrams. You will be prompted for additional info about your specific model, then you will be able to see the diagrams. From there you can also find out if th part is still available and which other models the part was used on.
1980 choke linkage questions 23 Sep 2014 08:39 #648480
  • chonus
awesome! thanks guys. I have it put together right but I have 2 things goin on. first the spring is weak and I believe the choke shaft is bent on one side. the carbs wobble when the brackets are off and you rotate the choke shaft. but only on the right 2 carbs
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
  • Page:
  • 1
