  • Page:
  • 1
KZ550 do Zephyr 550 carbs fit? 22 Apr 2014 08:43 #629955
  • accubond
  • accubond's Avatar Topic Author
  • Thank you received: 0
Hi,
just interested if the Zephyr550 carbs would fit a KZ550?
Regardds David
KZ550 do Zephyr 550 carbs fit? 22 Apr 2014 23:42 #630046
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Depends on which KZ550. The later motors have wider-spaced screws on the intake manifolds. This makes it possible to use the larger carbs. The older motors won't let you install the wider intake manifolds.
KZ550 do Zephyr 550 carbs fit? 23 Apr 2014 04:38 #630051
  • harm
  • harm's Avatar
  • Tom
  • Thank you received: 13
what carbs do the Zephyr use? That is an interesting idea..
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
KZ550 do Zephyr 550 carbs fit? 23 Apr 2014 04:41 #630052
  • accubond
So my engine number is KZ550DE0001X.
It should be a GPZ550 engine,right?
What is the HP?
So I can only use the Tk21/22 carbs?
KZ550 do Zephyr 550 carbs fit? 23 Apr 2014 06:11 #630055
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1625
From the engine no. info at CycleChaos, I guess the bike is an 81 KZ550-D1 ?
The max hp listed there is 58 hp @ 9000 rpms.
Try the VIN search at Kawasaki.com -->> Owner Info -->> Parts diagrams -->> etc
Last edit: by martin_csr.
KZ550 do Zephyr 550 carbs fit? 23 Apr 2014 09:08 #630074
  • loudhvx
  • loudhvx's Avatar
Harm, I think the ZR550B uses Keihin CV30 carbs.
  • Page:
  • 1
