Stuck intake boots
- nickleo373
Stuck intake boots
03 Oct 2013 22:47
Hey everyone
I noticed the screws to my carb intake boots are stuck. I believe they are just overtightned and not rusted into the engine. If I try to remove them with the JIS screwdriver it will probably strip the screws. I've tried using penetration oil and I've tried freezing the screw to get it out. Does anyone know a way to take the screw out of the engine without stripping anything?
1981 KZ550C LTD
"If you ain't first, you're last"
- MFolks
Re: Stuck intake boots
03 Oct 2013 22:58
Kroil is what I've used to free up my bike's intake boot screws. Apply heat(usually a hair dryer on high gets hot enough), & then the Kroil, let it work for a few days. Replace the screws with SS socket head cap screws(Allen Head). Before installation, and to prevent galling, put a little of the silver anti-seize on the new screws first few threads, it will make working on them easier next time.
- nickleo373
03 Oct 2013 23:05
Thanks MFolks. I've been trying to find kroil in my auto parts store and local hardware stores but they don't seem to carry it so I've been using Liquid wrench and PB blaster. Do you know where I would be able to buy some?
1981 KZ550C LTD
- MFolks
03 Oct 2013 23:13
I'd ask around before ordering online, as it's pressurized aerosol, and probably needs to travel by ground transport.
Maybe Amazon.com can help you, or here at Kroil's website:
www.kanolabs.com/msn/
The following user(s) said Thank You: nickleo373
04 Oct 2013 00:14
Here's the Kroil I bought (see the 10th section down on the Kano Labs Order Form at
secure.cnchost.com/kanolabs.com/orders/order.shtml
It isn't an aerosol, it's just liquid in a can with a thin spout.
Kroil 1/2 pint (8 oz.) can - $9.25 ea.
I soaked those screws for 3 days and used my JIS (modified Phillips) bits and those carb holder screws came out without deforming the screw heads at all - even though they were very tight. They had not ever been removed in 30 years.
Another place you may find it locally is at a gun show or possibly a gun shop. Ed
Attachment Kroil_2013-10-03.jpg not found
