Running on one cylinder
  • jacksdad
  • jacksdad's Avatar Topic Author
  • 1979 kz 750 OUCH, IT SPARKED
15 Apr 2013 14:46
#582476
So I have figured it i'm only running on one cylinder, its a twin,
I have observed fuel getting to the carburetor, am getting spark on that side, anybody got any ideas as to why,
After a short ride in the neighborhood, came back to check temperate of exhaust,.right side, about 175, left side, not even a hundred.
Any advice as to what to start checking for would be greatly appreciated.
1979 kz750 twin cyl.
Re: Running on one cylinder
15 Apr 2013 15:03
#582479
Could start with compression test and assure valve clearances within specs.
Good Fortune! :)
  • stevie g
  • stevie g's Avatar
15 Apr 2013 15:55
#582490
Have you tried swapping over the plugs ? just because it's firing does not mean that the plug is good. I've bought new duff plugs before. Other than that you could look to see if any of the jets are blocked. I would start at the plug though, then the cap, lead, try swapping the coils over and if it's definitely sparking then try the fuel supply starting from the tank down, fuel line etc.
stephen g mackay
  • jacksdad
15 Apr 2013 19:06
#582528
What y'all think, 175 after a mile long ride, at 25-30 sound good?
  • steell
  • steell's Avatar
15 Apr 2013 19:26
#582533
I think it's way to cold, seems like 300 or so would be right.
A lot depends on ambient air temp also.
  • jacksdad
15 Apr 2013 19:46
#582536
It was high 50's, low 60's
  • jacksdad
20 Apr 2013 12:30
#583276
Is this float upside down?
  • jacksdad
20 Apr 2013 12:31
#583277
Supposed to be a picture?
  • jacksdad
20 Apr 2013 12:40
#583278
There it is.
  • jacksdad
20 Apr 2013 22:40
#583372
Nevermind, figures it out, dumb me had a crimp in the left fuel line.
Feeling kinda stupid right now.
  • jacksdad
20 Apr 2013 22:41
#583373
Can delete thead
20 Apr 2013 22:59
#583379
jacksdad wrote: Nevermind, figures it out, dumb me had a crimp in the left fuel line.
I'm glad I never did that (well, only once). :laugh: Ed
