CV34's for KZ1000 or find better?
- whitskz
14 Jul 2012 01:44
i am building a kz bobber which started as a 82 kz750h. the 750 motor was shot so i found a 78 kz1000 motor for the build. the only carbs i have are the dual butterfly CV34's from the 750. can these be jetted/modded for a 1000 motor? they line up and fit fine with intake manifolds swapped. this will be a street bike, no motor mods, just want it to run like a stocker would have. should i get some VM28's assuming thats what the 78 came with? thanks
- zukdave
Re: CV34's for KZ1000 or find better?
15 Jul 2012 16:02
I'd worry about carb.'s till after you figger
out what it will take to shoehorn that motor in the 750 frame.
It ain't gonna be a bolt in and go swap.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- pete greek1
15 Jul 2012 18:04
how do you plan on getting a 1000 motor in a 750 frame ????
- whitskz
15 Jul 2012 21:49
this aint my first barbecue guys... just dont have in depth kz carb knowledge like im sure some of you on here do.
- whitskz
17 Jul 2012 20:48
So does anyone have any info as far as jetting to set these up for the 1000??
- roy-b-boy-b
17 Jul 2012 23:21
40/140 with pods.
