setting up float levels - wet
  • KZ1000inaus
  • KZ1000inaus's Avatar Topic Author
  • Luminous Red KZ1000 A2
11 Jul 2012 01:33
#535198
what other fluid apart from petrol can i use as wet setup for carb floats?
I'm sure i read somewhere on another thread about a guy who used something else as gas stinks the house out (garage adjoined to house)
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: setting up float levels - wet
11 Jul 2012 01:46 - 11 Jul 2012 01:47
#535201
Water! But after you are done with the adjustments make sure to remove every drop of water. Drain the bowls and 8se compressed air (not a lot of pressure) via the fuel inlet line to make sure it is all out of the lines. The water can really make it run crappy.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 11 Jul 2012 01:47 by KZJOE900.
  • martin_csr
  • martin_csr's Avatar
11 Jul 2012 09:52 - 22 Jan 2013 20:44
#535225
Last edit: 22 Jan 2013 20:44 by martin_csr.
11 Jul 2012 11:12 - 11 Jul 2012 11:14
#535239
The level at which a float floats will vary depending upon the specific gravity (density) of the liquid in which it is floating. Think of going for a swim in fresh water versus in the Great Salt Lake; you couldn't sink if you tried in the Great Salt Lake. So, if using something other than gasoline to do the clear tube test it is best to use a liquid that has a specific gravity that is at least fairy close to that of gasoline. As Martin points out, the density of alcohol is pretty close to that of gasoline; so is olive oil. Below is a link to a table that shows the specific gravity of several different liquids. This may help you decide what to use for your clear tube test.
www.engineeringtoolbox.com/specific-gravity-liquids-d_336.html
Last edit: 11 Jul 2012 11:14 by 650ed.
