How to connect the fuel lines? (with pictures)
- BMAC-Z1900
08 May 2012 23:30 #520872
by BMAC-Z1900
How to connect the fuel lines? (with pictures) was created by BMAC-Z1900
Alright guys. I have a project bike I've been working on. Its a 74' Z1 900 with a 73' Z1 900 motor. As Im going to put on the gas tank and connect the fuel lines, it looks like the fuel lines from the carbs have either been cut off or jerked off and I dont know how to connect them.
Here is a picture of the fuel lines. Where do they connect to?
And here is another picture with a bigger line that has also been cut. This line runs up and under the seat at the base of the tank but looks like it has been cut. You can see this in the first picture. Here is the bigger line im talking about.
And here is a picture of the bike as it sits
- DoubleDub
- Visitor
08 May 2012 23:46 #520876
by DoubleDub
Replied by DoubleDub on topic How to connect the fuel lines? (with pictures)
They should just fit over the nipples on your petcock on the gas tank. If you replace the line (might be a good idea) you can run without clamps, although some would recommend them anyways.
The second line is the engine breather. I can't say for sure on the Z1's where that goes, but on my Kz900 there was originally a small hose that went from the breather to the bottom of the airbox.
- BMAC-Z1900
09 May 2012 07:04 #520926
by BMAC-Z1900
Replied by BMAC-Z1900 on topic How to connect the fuel lines? (with pictures)
But the part I'm trying to figure out is I have four fuel lines, (one from each carb) and ONE nipple on the petcock??
- Old Man Rock
- Thank you received: 225
09 May 2012 08:47 #520934
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic How to connect the fuel lines? (with pictures)
Stock VM 28mm carbs, only 2 fuel inlets (#1) for two carb bodies... Have another (#1) for the other two carbs. The other two hoses your finding maybe #2 (Vent Pipes). Need to confirm which carbs you have.
Attachment MukuniCarbsIdentification.JPG not found
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2098
09 May 2012 09:13 #520940
by Patton
Replied by Patton on topic How to connect the fuel lines? (with pictures)
Original Z1 petcock has two fuel outlet nipples.
Original Z1 has two fuel lines.
One fuel line attaches to one petcock nipple.
The other fuel line attaches to the other petcock nipple.
If the petcock has been replaced with another petcock that has only a single fuel outlet nipple, use a tee fitting in the single line from the single petcock nipple to provide a fuel nipple for each of the two fuel lines.
Besides the two fuel lines, there are also two carb VENT hoses.
Each VENT hose must exit to open air.
Each VENT hose is routed from the carbs to exit to open air underneath the bike or underneath the seat.
On a stock Z1, the crankcase vent connects via an "S" shaped hose into the air box.
The crank case may alternatively be vented through a hose exiting underneath the bike.
Attachment crankcaseventhose.jpg not found
09 May 2012 10:07 #520950
by Patton
Attachment Z1petcocktxt.JPG not found
Attachment Z1fuellinepetcock2.jpg not found
Attachment Z1fuellinepetcock.jpg not found
- Thank you received: 2829
09 May 2012 10:34 - 09 May 2012 10:35 #520961
by 650ed
Replied by 650ed on topic How to connect the fuel lines? (with pictures)
Get some of these (not necessarily from eBay) to fasten the fuel line to the tank; they make removing and reconnecting the fuel line very easy.
motors.shop.ebay.com/altha1/m.html?_nkw=..._sop=1&_udhi=&_udlo=
Last edit: 09 May 2012 10:35 by 650ed.
- BMAC-Z1900
09 May 2012 11:51 #520984
by BMAC-Z1900
Wow, thanks guys that exactly what I needed. I went ahead and ordered the original z1 petcock with the two nipples. Would you guys suggest an inline fuel filter?T
09 May 2012 11:53 #520986
by 650ed
Unless your fuel tank is squeaky clean inside - yes; and even if it is it's not a bad idea. Ed
09 May 2012 12:36 - 09 May 2012 12:37 #520993
by Patton
Yes, in each and every fuel line so that no gasoline ever reaches the carbs without having first passed through an in-line filter.
www.z1enterprises.com/detail.aspx?ID=293
BMAC-Z1900 wrote: ...Would you guys suggest an inline fuel filter?T
Attachment filterZ1.jpg not found
Last edit: 09 May 2012 12:37 by Patton.
09 May 2012 12:43 #520994
by Patton
Where needed to help avoid kinking or otherwise improve fuel line routing, the 90° in-line filter could be another option.
