Manual petcock on kz750 csr?
  • bcbobber
  • Topic Author
24 Apr 2012 03:52 #517721 by bcbobber
Manual petcock on kz750 csr? was created by bcbobber
Just wondering if I can just replace the vacuum petcock on the CSR with a manual petcock, and if so would I just cap off the vac port that goes to the petcock? Thanks guys you are much help.
24 Apr 2012 08:57 #517739 by AtLarge
Replied by AtLarge on topic Manual petcock on kz750 csr?
Yes, you can and yes, you do. I don't use my stock vacuum petcock anymore. Never could get it adjusted right even with a rebuild kit. More trouble than it's worth and when it's turned off I know no gas is getting through.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
  • bcbobber
  • Topic Author
25 Apr 2012 00:13 #517928 by bcbobber
Replied by bcbobber on topic Manual petcock on kz750 csr?
Thanks AtLarge, that's what I figured but just wanted to make sure. yes I know what you mean about the vac petcock...no fun at all! :sick:
25 Apr 2012 00:19 #517930 by AtLarge
Just a suggestion... Do a search on Fleabay for a seller named Brown Family Racing. He's got good ones. Reasonably priced. Work great. Contact him directly and he'll fix you up with one exactly for your bike.
1973 Honda CL70-K3
1994 BMW K1100RS
  • bcbobber
  • Topic Author
26 Apr 2012 00:51 #518130 by bcbobber
Thanks again atlarge, found the brown family racing guy on ebay and he had some specifically machined for the kz750 csr so I got that on order and will let you know how it works out when I get it and hook it all up.
26 Apr 2012 09:42 - 04 May 2015 15:47 #518166 by martin_csr
Replied by martin_csr on topic -
Manual fuel valve.
If the bolt hole spacing is 34mm & I'm pretty sure it is on the CSR:
KZR topic - Manual fuel valve option
Last edit: 04 May 2015 15:47 by martin_csr.
  • bcbobber
  • Topic Author
26 Apr 2012 20:05 #518259 by bcbobber
One more question. When i get the knew petcock do I just cap the vac tube on the petcock and the vac line going to the petcock and leave the two vac lines hooked to the carbs? Or do I cap all the vac lines up? I'm assuming the first, but just want to make sure.
26 Apr 2012 20:31 #518267 by Patton
Replied by Patton on topic Manual petcock on kz750 csr?
bcbobber wrote: One more question. When i get the knew petcock do I just cap the vac tube on the petcock and the vac line going to the petcock and leave the two vac lines hooked to the carbs? Or do I cap all the vac lines up? I'm assuming the first, but just want to make sure.
With the new petcock installed, remove the vacuum hose that's no longer needed, and cap/plug the vacuum nipple where the hose was removed.
All the vacuum nipples should now be capped/plugged.
Leave the two vent hoses alone. They must exit to open air, usually through hoses routed to underneath the seat or routed to underneath the bike.
Good Fortune! :)
  • bcbobber
  • Topic Author
30 Apr 2012 02:18 #518757 by bcbobber
So I should take the hose vac hose off the two carb nipples and the petcock nipple as well? Just want to make sure I understand you correctly. Then cap all three?
30 Apr 2012 08:27 #518771 by AtLarge
I wouldn't. Either take the petcock vacuum hose, plug it and leave it dangle or take the line with the tee out and replce it with one solid piece from the carb to canister that is in the top of the air cleaner.
1973 Honda CL70-K3
1994 BMW K1100RS
30 Apr 2012 08:37 #518773 by Medina
Replied by Medina on topic Manual petcock on kz750 csr?
I converted mine from vacuum to manual. A thread here details it.
Haven't had any problems with it. doesn't leak and cost was...less than a couple of bucks and wait time was overnight. I plugged the unneeded vacuum line with the same two part epoxy I used internally.
edit: gas tank designed two part epoxy ;)
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
  • bcbobber
  • Topic Author
30 Apr 2012 20:20 #518887 by bcbobber
Thanks that's what I was thinking as well at large. Just wanted to make sure because i got the petcock today and am going to hook it up tonight and see If I can get her fired up. :)
