HELP pls. 33 mikuni smoothbores
  • Harvey1327
  • Harvey1327's Avatar Topic Author
27 Apr 2011 19:56
#447433
Hello,
I have a set of 33 mikuni smoothbores with a broken float tower.
Attachment IMG_0900.JPG not found
Can it be repaired or am I F#*@%D
Thankyou Harvey
Would anyone have a no.1 carby to replace v33 14
Again thankyou Harvey
Attachment IMG_0906.JPG not found
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
Re: HELP pls. 33 mikuni smoothbores
27 Apr 2011 23:24
#447461
:unsure: Still have the piece that broke off?
  • COE1948
  • COE1948's Avatar
27 Apr 2011 23:53
#447468
Graeme you may be able to drill and pin it or we could drill and tap the carby body and make a new post to hold the float pin and screw it into the tapped hole in the body give me a call
Regards Dale
1x1973 Z1900,2x1974 Z1A900,2x1975 Z1B900,2x1976 KZ900s & 2x79KZ1300
XS1100 Yamaha solo
XS1100 Yamaha with DJP sidecar
FJ1100 Yamaha
  • Harvey1327
28 Apr 2011 06:11
#447505
Patton wrote: :unsure: Still have the piece that broke off?
yes in my right hand with a hammer in the left.:whistle: :blush:
I got a link from Kraz1 to "motorcyclecarb.com.inc" They do
alluminium laser welding on carb float posts.:cheer: :cheer:
Thankyou Harvey
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
  • Harvey1327
28 Apr 2011 06:16
#447506
COE1948 wrote: Graeme you may be able to drill and pin it or we could drill and tap the carby body and make a new post to hold the float pin and screw it into the tapped hole in the body give me a call
Regards Dale
Thanks Dale I'll give "motorcyclecarb.com.inc" a call.
What was that forum you metioned earlier. text if you want.
Thanks Graeme
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
28 Apr 2011 09:49
#447523
Alternative to welding, and as a possible supplement to drilling and pinning, might consider JBWeld.
Could use JBWeld and a tubular brass sleeve (for added support) over the round portion of the post (upper and lower) with the sleeve relieved to fit down over the stump.
Alternatively, could JBWeld the broken piece onto the stump, and add a vertical brass "slat" on opposing sides of the post along the rounded portions to help hold the broken piece onto the stump.
When applied correctly, JBWeld will survive a long time submerged in gasoline.
Good Fortune! :)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Apr 2011 15:40
#447728
Patton wrote: When applied correctly, JBWeld will survive a long time submerged in gasoline.
Good Fortune! :)
to my knowledge there is only 1 way to apply jbweld, kneed and stick. i have found that it deteriorates in a float bowl.
do u have a special method of aplication?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
29 Apr 2011 17:10 - 29 Apr 2011 17:12
#447742
Some very reliable folks have reported good results from using JBWeld to repair broken float tower posts as well as cracked or broken over-flow tubes, and as I recall, also pin holes or cracks in a fuel tank.
For example, see the following:
Click > kzrider.com/forum/3-carburetor/179315-oooh-nooooo#179320
An uncertain, but vaguely recalling from other readings that attempted JBWeld repair failures may result from improper application or insufficient set-up time allowed before placing into service.
Perhaps ethanol might be a factor? :unsure:
Good Fortune! :)
Last edit: 29 Apr 2011 17:12 by Patton.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Apr 2011 19:25
#447751
the ethanal content is higher these days. the jb weld went funky on mine . now i am using gas tank repair, but it is going bad too. i will try to weld them next.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
