  • Page:
  • 1
DIY rubber gaskets made out of bicycle innertube? 06 Jul 2010 21:40 #380712
  • kz.chris
  • kz.chris's Avatar Topic Author
  • Thank you received: 0
Has anyone ever tried this on a set of carbs?
I'm doing an entire tear down/rebuild of a 4 carb assembly i got off ebay.
I will already have to make a few parts on a lathe and i figure if I can save a few bucks on gaskets why not.
the entire assembly only cost me $20 bucks so if i can get away with something that works well and keep the entire project under 50 bucks ill be very happy.
Any other thoughts or ideas?
Thanks
1977 Kawasaki KZ650
DIY rubber gaskets made out of bicycle innertube? 06 Jul 2010 23:39 #380724
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
Inner tube rubber will disintegrate if hit by gasoline. I have used it to make vibration damper type gaskets for mounting the odd piece, but nothing related to fuel.
DIY rubber gaskets made out of bicycle innertube? 07 Jul 2010 00:17 #380727
  • kz.chris
i was afraid of that.
i just picked up some gaskets from z1.
thanks
1977 Kawasaki KZ650
DIY rubber gaskets made out of bicycle innertube? 07 Jul 2010 09:54 #380790
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Yeah, even just being exposed to sunlight for 8 hours or so degrades an inner tube. I used them to hold some turn signals together. By the end of one day you could see the rubber cracking.
DIY rubber gaskets made out of bicycle innertube? 07 Jul 2010 10:34 #380798
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
  • Thank you received: 28
OEM, or better.
If you keep it under $50, you might have some kind of guiness record or something! :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
DIY rubber gaskets made out of bicycle innertube? 07 Jul 2010 15:35 #380848
  • mjkawa
  • mjkawa's Avatar
I was thinking of the same thing for gaskets between the carb holders, and the head.
Is this totally crazy?
They wont see any sunlight, but will see some gas, and heat.
Existing carb holders seem ok, with little indentations from where they were mounted. And I definately have air leak on the intake.
Just trying to save $80 for some new ones from z1e.
82 KZ-1000-J
77 KZ650 B
DIY rubber gaskets made out of bicycle innertube? 07 Jul 2010 16:50 #380864
  • loudhvx
  • loudhvx's Avatar
Why not just get some legitimate gasket material? I made some out of paper material that worked fine (between carb holders and the head). There are other materials that may be better than paper, like the rubber-impregnated cork gasket material available at most auto parts stores. It was like $5 for 1 or 2 square feet.
DIY rubber gaskets made out of bicycle innertube? 07 Jul 2010 20:12 #380936
  • TerryK
  • TerryK's Avatar
You cant be that cheap, spend the 80 bucks and fix it PROPERLY. You'll thank me later.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • Page:
  • 1
