Leaking petcock?
  • switch
  • switch's Avatar Topic Author
  • 1981 KZ1000m CSR
Leaking petcock?
29 Nov 2009 13:33
#336521
I have cleaned my tank and replaced the petcock, cap, and float. I filled it and have it sitting off the bike while I wait for Z1E to send my airbox hoses.
I am getting a slow leak from the petcock. It is not from the gasket around the unit, it is through the fuel pipe into the fuel hose.
Since I don't have the vacuum hose hooked up, can I expect to have this leakage occur when I do hook up the tank to the carbs?
This is a 81 KZ100 M1 CSR.
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
  • bountyhunter
  • bountyhunter's Avatar
Re: Leaking petcock?
29 Nov 2009 14:44 - 29 Nov 2009 14:45
#336548
Maybe not seep when the carbs are hooked up, depends how well the vacuum valve cuts the fuel off. If the floats/needles in the carbs are good, they may stop the gas from over flowing. A lot of petcocks seep a little gas.
Last edit: 29 Nov 2009 14:45 by bountyhunter.
  • JR
  • JR's Avatar
29 Nov 2009 16:21 - 29 Nov 2009 16:26
#336581
I love the vacuum activated petcok when they are working but they can be a PITA when they malfunction. My carbs will overflow if the petcock leaks. In theory float valves should stop the gas but in practice it doesnt happen. What can I expect with 30 year old carbs :laugh:
I have had the same problem and would suggest taking the petcock apart and taking a look at the spring that pushes on the little rubber diaphragm.
It should look like this NNNNNN. Stretch it out a little so it looks like this NNNNNNNN and put it back. I hope this helps.
Last edit: 29 Nov 2009 16:26 by JR.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
29 Nov 2009 16:28
#336586
Only when bike is running would produce vacuum to open the petcock. In time, they may sip a little, but I wouldn't expect a new petcok leaking at all, if position is not in prime.
  • bill_wilcox100
  • bill_wilcox100's Avatar
29 Nov 2009 22:43
#336657
switch,
As you have gathered from the great advise above, a properly installed and properly working petcock with good gas lines and clamps should never leak. If it does leak then I would repair or replace before riding season.
On an unrelated subject, did you add a premium quality clear inline Fuel Filter between the petcock and the carbs? IMHO, this is not optional in 30+ year old fuel tanks... don't ask. :blush:
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
