'81 KZ1000J Float Height
- kzmason
29 Mar 2007 14:08
Anyone know what the spec is for this, I can't find it in the manual I have.
- oldcoldankles
Re: '81 KZ1000J Float Height
29 Mar 2007 17:03
My manual says 18.6mm from the float bowl mating surface to the top of the floats. Good luck:)
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- wiredgeorge
30 Mar 2007 12:29
Since the floats have been bent up over the years... not the tang where they are supposed to be adjusted but the whole float body, I suspect this measurement is pretty useless. Use the service fuel level method described in your manual for an accurate amount of fuel in your bowls.
- Duck
- e vica na i sau na ga
30 Mar 2007 15:58
What George says.
An added benefit is you'll learn if the float valves are doing their job and not sticking/leaking BEFORE remounting carbs on the bike. You may need to dress the float needle seats to get a good seal.
-Duck
-Duck
