  • Page:
  • 1
  • 2
Cam bearing clearance 05 Oct 2021 08:52 #856214
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2649
That explains it. It was milled because it was warped? If that's the case homing may be the only option.
Last edit: by SWest. Reason: Add clip
Cam bearing clearance 05 Oct 2021 09:35 #856216
  • Southpaw
  • Southpaw's Avatar Topic Author
  • Thank you received: 5
Both cams self destructed. Just checked the journal diameter there are on the high side of the tolerance in the manual
Cam bearing clearance 05 Oct 2021 09:52 #856217
  • SWest
  • SWest's Avatar
  • 10 22 2014
I don't understand self destructed. Did it overheat, warp and the cams sized in the bores?
Cam bearing clearance 05 Oct 2021 10:09 #856218
  • Southpaw
I put new bearings in when i originally built the engine, they were too tight i did not check the clearance. Ran it and the bearings and journals got destroyed. Im Starting over trying to avoid that happening again. FBG skimmed the head because its part of there head service. I never thought about the head being warpped causing the clearance issue
Last edit: by Southpaw.
Cam bearing clearance 05 Oct 2021 11:55 #856222
  • SWest
  • SWest's Avatar
  • 10 22 2014
That could be what happened. Honing the bearings or couple won't hurt to get to .001-3.
Cam bearing clearance 06 Oct 2021 06:14 #856255
  • Southpaw
So the honing seems to have done the trick exhaust cam is spinning freely now. Now to check the intake side. Thank you all for your help i appreciate it
  • Page:
  • 1
  • 2
