Zukiworks build's a ZRX 26 Nov 2017 05:44 #775094
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
Well I've had some time to mess with this and got to take it for a little test ride last night.
I still need to go by Dan's and get an air box setup then will be able to get it out for a real test ride.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Zukiworks build's a ZRX 29 Nov 2017 18:36 #775319
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
What did you do with the green white and purple tank and the Muzzy pipe that came with the zrx?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Zukiworks build's a ZRX 30 Nov 2017 05:04 #775331
  • zukdave
Long story on that but I did some trading with Will I got this bike from that I ended up with the black tank and left side Muzzy
pipe and both the ZRX and the ZX-11 for free.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Zukiworks build's a ZRX 02 Dec 2017 06:34 #775415
  • zukdave
Was able to get this out for a shake down ride last night put about 10 miles on it with no issue's.
Did a few part throttle test hit's and with no burnout on a cold tire/street it wass lifting the front wheel through
second gear and pull's real strong.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Zukiworks build's a ZRX 09 Dec 2017 07:03 #775766
  • zukdave
Last Sunday got to spend the day going some cleanup and paint touch up on the motor.
Rad. and screen cleaned and repainted.
Pulled the header off and hit it with some Works bowl cleaner and a green scotchbrite pad.
Before.
After.
The black tank just looked to out of place to me so hit it with some gray primer.
After that got out for a little ride with my buddy Dan
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Zukiworks build's a ZRX 10 Dec 2017 06:48 #775791
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
Your header cleaned up great!
Are they stainless?
Who's bike is faster, yours or Dan's?
78 KZ1000 A2A
Zukiworks build's a ZRX 10 Dec 2017 07:09 #775792
  • zukdave
Yes it's stainless.
As far as faster don't know yet we haven't ran them but Dan's is stock with a pipe,
pods and a jet kit and should make mid. to high 90's hp at the tire and I'm thinking I shoud be about 130 + hp at the tire.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Zukiworks build's a ZRX 10 Dec 2017 17:03 #775812
  • zukdave
A buddy Chris came by and showed me this new seat he got for his rex and I gotta have one.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Zukiworks build's a ZRX 12 Dec 2017 14:12 #775921
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Wow that header looks awesome! I have a super crusty stainless Yoshimura exhaust I need to clean up Ill give that stuff a try. Its so oxidized in places it looks black, I think it had header wrap on it at some point.
Last edit: by DoctoRot.
Zukiworks build's a ZRX 12 Dec 2017 19:35 #775945
  • zukdave
I've read about using it on stainless and this was the first time I tried it.
Using rubber gloves I poured some on the scotchbrite and scrubbed the pipe then a water rinse. took about an hour's time.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Zukiworks build's a ZRX 12 Dec 2017 20:49 #775947
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 518
zukdave wrote: Pulled the header off and hit it with some Works bowl cleaner and a green scotchbrite pad.
I was curious, so I looked up the MSDS for The Works Toilet Bowl Cleaner. I just thought I'd mention that the active ingredient is Hydrochloric Acid. I don't have any opinion about that, but I figured maybe someone else might be curious as well. Using gloves seems like a good idea, as well as a thorough washing of the parts after cleaning.
The Works Toilet Bowl Cleaner SDS
My dad's '74 Z1
'00 ZRX1100
Zukiworks build's a ZRX 14 Dec 2017 08:12 #776026
  • DoctoRot
  • DoctoRot's Avatar
hydrocloric acid is super cheap, i have a bunch of it for cleaning gas tanks, maybe Ill give that a try.
