  • Page:
  • 1
  • 2
What you guys use for a piston base tool? 20 May 2023 19:05 #885003
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
  • Thank you received: 34
dunno I've only used the factory tool one time and was nice to use but it seems like those two U shaped jobbys could easily be duplicated. Anyone using anything else that also works well?
1982 KZ1100D1
What you guys use for a piston base tool? 20 May 2023 19:26 #885005
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 312
I've made a couple sets out wood. I sand them smooth to prevent splinters and use motor oil for sealer.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
The following user(s) said Thank You: Gdailey2112
What you guys use for a piston base tool? 20 May 2023 20:56 #885010
  • Gdailey2112
  • 82 KZ1100D1
wondering mostly what the dimensions are for those two long U shaped rods
1982 KZ1100D1
What you guys use for a piston base tool? 21 May 2023 04:16 #885018
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1040
Are you asking about the coathanger sized U shaped ones that go under the pistons to hold them all at the same elevation?
What you guys use for a piston base tool? 21 May 2023 13:01 #885049
  • Gdailey2112
  • 82 KZ1100D1
Yes but I think it likely needs to be wire of a specific gauge just a little larger gauge than a wire coat hanger maybe even 2x thicker than.
sure does make one helluva difference on doing the task lowering the jugs.
1982 KZ1100D1
Last edit: by Gdailey2112.
What you guys use for a piston base tool? 21 May 2023 15:36 #885051
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1983
You will find  Joe at Pitstop tells you all you will need to know and has easy dimensions  for the piston  holding  wood block They work great from my personal experience Dave  file:///C:/Users/Dave%20A/Documents/Top%20End%20Assembly%20_%20pitstopperformance.html
My computer hates me.. Let me try and fix it for the pitstop performance link
Last edit: by Street Fighter LTD.
What you guys use for a piston base tool? 21 May 2023 19:22 #885056
  • hardrockminer
I made a couple out of coathangers.  Worked fine.
What you guys use for a piston base tool? 22 May 2023 05:21 #885061
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Online
  • Thank you received: 645
Wire coat hangers with enough layers of shrink wrap to achieve the necessary diameter & protect aluminum surfaces.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
What you guys use for a piston base tool? 22 May 2023 08:30 #885065
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
Good Ridin'
slmjim & Z1BEBE
That is a GREAT suggestion!  (IMHO)   Pistons other than OEM will have varying skirt heights, so this is a great idea to change the diameter of the rods.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
Last edit: by KZQ.
What you guys use for a piston base tool? 22 May 2023 13:04 #885074
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
Like a fool a few years back I had to sell my Kawasaki Kz1000 ring compressor tool. I used that Kawasaki tool on 72mm and 73mm pistons on my Kz1000 motors. I still regret selling that ring compressor to this day. What I use now are the band type ring compressor tools. Only need two of them. You do the two inner pistons first, then the outer two. I use two pieces of wood cut to fit the pistons I am using in that motor to sit level as I then slide the barrel down on to those two inner pistons. Then I move the two outer pistons to near TDC and then level those pistons and  gently tap the barrel down over the last two pistons. Still wish I had my fancy Kawasaki ring compressor tool......
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: Gdailey2112, howardhb
What you guys use for a piston base tool? 23 May 2023 20:40 #885119
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 90
I like these Honda Ring compressors for the CB450 and The piston blocks are 1/2 inch MDF with correct cutout for the rod and long enough to support the piston.
What you guys use for a piston base tool? 24 May 2023 11:13 #885132
  • Gdailey2112
  • 82 KZ1100D1
Great ideas for sure! Thanx so much
1982 KZ1100D1
  • Page:
  • 1
  • 2
