  • Page:
  • 1
Tyre pump for where there's little space 19 Dec 2022 11:00 #877987
  • Michi
  • Michi's Avatar Topic Author
  • Thank you received: 18
Anyone got any recommendations for a tyre inflator where there's little space for the nozzle? Most of them these days seem to be flip-up types (you flip up a lever and it clamps down on the valve). I've got 2 of them: a good bicycle pump, and a 12V DC (car type) compressor. Problem I've got it, the nozzles are too big for the rear tyre on my KZ440 LTD project. No chance to flip up the lever, and in one case no way to fit the nozzle onto the valve in the first place. So I need to get another one. As you will be aware if you have an LTD, there isn't much space between the valve and the centre of the rim (housing the drum brake). If you've got an LTD and you know which inflator can be used for the rear tyre, a pointer on Ebay or something would be great. Thanks
KZ440A LTD (1980)
Last edit: by Michi.
Tyre pump for where there's little space 19 Dec 2022 11:34 #877990
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1915
Any good car parts or tyre shop should sell angle adapter for tyre valves.
The following user(s) said Thank You: Michi
Tyre pump for where there's little space 19 Dec 2022 11:48 #877991
  • Michi
Ah, perfect solution!
KZ440A LTD (1980)
Tyre pump for where there's little space 19 Dec 2022 11:58 #877992
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
Why cant a regular chuck fit?  Pics?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Tyre pump for where there's little space 19 Dec 2022 14:05 #877997
  • Michi
Aka a push-on compressor line. Sure, that would work too. Just haven't got one. I've got a car cigarette-lighter-powered inflator, and a freestanding bicycle pump. I don't mind buying stuff, but the angled adaptor makes more sense as I'm pressed for space.
KZ440A LTD (1980)
Tyre pump for where there's little space 19 Dec 2022 15:44 #877999
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 139
For a quick fix, that 90 degree adaptor should do the trick. But it does provide another junction for an air leak. The next time you replace tires, put in 90 degree valve stems.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
The following user(s) said Thank You: washoe1
Tyre pump for where there's little space 19 Dec 2022 18:27 #878010
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 355
I bought a cheap Harbor Freight pump that works with a KZ440 rear.
Problem is...they don't make that pump anymore.
You could do a google search for replacement bike pump heads.
bike pump head search results
81-KZ440-D2.
LIC, NY
  • Page:
  • 1
