  • Page:
  • 1
  • 2
rotor tool (alternator act) kawa part no 57001-308 18 Apr 2015 19:57 #668609
  • Randombeat
  • Randombeat's Avatar Topic Author
  • 0 to 100 real quick...
  • Thank you received: 23
FSM says I need this tool to hold the alternator rotor while I turn the secondary shaft but loose... I already order the flywheel puller bolt, but do I need the rotor tool also? I can't find one anywhere... *bangs head*
Attachment 1429411689809905573440.jpg not found
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 00:27 #668633
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 374
You do need to hold it from spinning some how. You might be able to do so with a strap wrench.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Randombeat
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 06:44 #668648
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
  • Thank you received: 80
No eBay APP ID and/or Cert ID defined in Kunena configurationI saw one of these tools on Ebay a few years back, and scooped it up. I have not seen one since. Seriously, someone needs to remake something like this, it doesn't look that difficult. If you find one, buy it! I have only seen something like this, but have no experience using it.
'85 GPz550(ZX550-A2)
The following user(s) said Thank You: !Seymore, Randombeat
Last edit: by CoreyClough. Reason: spelling
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 08:24 #668663
  • Thank you received: 2829
Last edit: by 650ed.
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 08:32 #668667
  • Randombeat
650ed wrote: .
Im glad you saw this, I was just about to link you to it in my other thread..
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 09:54 #668680
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
I used a Honda CB750 rear wheel spindle to force the rotor off, not sure of the thread but it came off easy enough. Locking the back wheel in gear will hold the rotor. Obvious, but never use a hammer on this!
I used some fine grinding paste to lap the crank nose taper/rotor, a good finishing touch.
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 10:17 #668685
  • Randombeat
Tyrell Corp wrote: I used a Honda CB750 rear wheel spindle to force the rotor off, not sure of the thread but it came off easy enough. Locking the back wheel in gear will hold the rotor. Obvious, but never use a hammer on this!
Thanks for the info! I'm doing the starter clutch, bike is an 1980 kz750h1 ltd. I don't think I need to actually pull the rotor, I just need to prevent it from turning while I try to loosen the secondary shaft nut...
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 10:47 #668687
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
put it in 5th gear and have someone step on the rear brake. Or you can pull the clutch cover and hold the clutch basket with a clutch wrench. EBC makes those.
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 13:19 #668716
Randombeat wrote:
650ed wrote: .
Take a look at the 2 links below. I believe they each contain information that should be helpful to you as you tackle the starter clutch. Ed
forums.kz650.info/index.php?action=dlatt...pic=586.0;attach=873
forums.kz650.info/index.php?topic=5152.0
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 15:14 #668736
  • Randombeat
650ed wrote:
Randombeat wrote:
650ed wrote: .
Thanks ed. The first link, I get the download, but it says can't open file.. Maybe its the tablet I'm on? Could you email it to This email address is being protected from spambots. You need JavaScript enabled to view it. ?
Thanks again
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 15:32 #668746
I sent it. It's a PDF file. Ed
rotor tool (alternator act) kawa part no 57001-308 19 Apr 2015 15:53 #668750
  • Randombeat
650ed wrote: I sent it. It's a PDF file. Ed
Can't thank you enough ed, this PDF is what I originally read, and makes no mention of any special tools. Just walls and broom handles lol.
  • Page:
  • 1
  • 2
