Make a degree wheel
- Becker
- The Doctor Will Rise Again
Make a degree wheel
15 Dec 2009 19:26
So I wanted a degree wheel but they are a bit expensive. So I copied this pic off the internet and took it to Paint brush and inverted the colors then took it to word and printed it. Next I cut it out and stapled it to a piece of posterboard (actually it was the cardboard from the back of a case of beer). You could print it straight to cardstock and cut that out and skip this completely. then I stapled it together. I think I'm going to try to get this connected to a thin piece of aluminum or steel somehow but for now it should work just fine. I'm including a pic of the finished product that is about 7 and a half inches across and the degree wheel as a file in microsoft word 07.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Becker
Re: Make a degree wheel
15 Dec 2009 19:27 - 15 Dec 2009 19:30Attachment Book2.xls not found
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Last edit: 15 Dec 2009 19:30 by Becker.
- Becker
15 Dec 2009 19:34
So apparently they don't upload word files so I copied into Excel. It should still be printable. I hope. If you have problems I can send it to you Via Email just pm me.
Attachment dw.xls not found
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- switch
- 1981 KZ1000m CSR
16 Dec 2009 21:23
Thanks for the effort. I tried to print the xl page, but it distorted. So.... I copied it back to a Word doc, and Presto! Full reproduction, I think. At least it is equal in x and y planes, and subsequently round! You said it was 7" diameter? My word doc (using "Narrow" margins) came out approx 6 1/2" diameter.
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
- Old Man Rock
18 Dec 2009 06:35
Due to the accuracy requirements... Z1 has degree wheels for under $20....
www.z1enterprises.com/detail.aspx?ID=2871
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- loudhvx
22 Dec 2009 06:28
I have a program that creates degree wheels. Right now, I have them in three sizes, but you can blow them up or reduce them as necessary if you have a good printer.
I haven't added the numbers yet, but that wouldn't be too hard, even if you just use a pen after printing.
You can open them in paint to edit them, but I recommend using some other program for printing them.
This first one is small. I use it on camshaft sprockets.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- loudhvx
22 Dec 2009 06:29
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
22 Dec 2009 06:30 - 22 Dec 2009 06:33
Here's the biggest one.
Edit: too big to post. I'll host it somewhere else and put a link here.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 22 Dec 2009 06:33 by loudhvx.
- Becker
22 Dec 2009 22:35
Dammit loudhvx. I had to look all over for a stupid cam degree wheel before I found something printable :laugh: That one looks like it would be much easier to use for etching onto a metal surface though which is what I want to do next. Thanks.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- loudhvx
22 Dec 2009 23:28
Guess i was a little late on the draw.
Here's a link to the biggest version I have.
home.comcast.net/~loudgpz/GPZweb/DegreeWheel/DegWheelBig.gif
Because the lines are 1 pixel wide, you really can't shrink them without losing lines, that's why I made several sizes. The smallest works well for camshaft degreeing without a crank. I used it to spec out the KZ550 series of cams, in case anyone is interested in 550 cams.
home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
1981 KZ550 D1 gpz.
Other links.
Other links.
- Kawickrice
24 Dec 2009 07:07 - 24 Dec 2009 07:11
here is one from the GS site that I use
Can not get to load. Here is a link, its under downloads toward the bottom
www.thegsresources.com/gs_garage.htm
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 24 Dec 2009 07:11 by Kawickrice.
- sicom
28 Jun 2012 00:19
Go to a hobbies store (like Hobby-Lobby or similar) and check the section with drawing tools. Usually within the rulers they have a nice round-transparent-plastic-degree ruler for about a dollar or two. I successfully used such a ruler to set and check for dwell angle on the points.
