Any one know how to make a cheep float level tool. I'm looking to set up a set of '77 kz650 carbs.
77KZ1000
76 KZ900
The administrator has disabled public write access.
Ruler.
Square, maybe rig something like a float tool with the two of em' Good luck. |
79 Kawie Z1000 LTD 81 Kawie Z1000 CSR 83 Honda VT750C A 85 Kawie GPZ900 A2 86 Zukie GS1150 EG 93 Yamie XV1100 E Lucky to have rolled many old bikes through my doors
A 12" length of clear plastic tubing with same o.d. as o.d. of the drain screw threads will "self-thread" into the drain screw hole and permit testing service float bowl fuel level.
There's also a fitting on ebay for less than $10 that's similar to the factory tool, basically a normal drain screw adapted with a nipple and clear hose. Good Luck! |
Last Edit: 3 years 7 months ago by Patton.
I just did mine this last weekend with the tool from the eBay seller. It's worth every penny. I'm sure you could get by jamming some clear tubing into the hole too, but the one that threads in is just really nice to have, especially for a fairly cheap price (when compared to the factory tool).
Get right or get left! <*{{{><
If its Dave from Bozeman Mt, he does nice work and is easy to deal with. I have a couple of his tools.
savedrider wrote:
I just did mine this last weekend with the tool from the eBay seller. I am looking for this as well. Searched Ebay, but no luck. Could you give me his seller ID or point me to his auction? Thanks, Jeroen |
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
Here ya go guy... KZ650 float tool
1980 KZ650F1, Bought new ($2,162.98) All stock except K&N, Dyna S, Andrews Coils, Acell wires.
Last Edit: 3 years 6 months ago by Bluemeanie.
The e-bay float tool works good. I have also took the tip off of a Papermate ink pen, thread it into the bowl drain hole and attach a clear hose.
76 Kawasaki KZ900
99 Kawasaki ZRX1100 03 Suzuki RM250 97 Kawasaki KDX220 71 Yamaha DT250 71 Penton 125 Six Day
Last Edit: 3 months 4 weeks ago by H1Vindicator.
With the "correct" size o.d. clear tube (i.e., tube o.d. about same as drain hole i.d.), simply self-thread the tube into the drain hole, which works fine and doesn't leak.
Carry the float bowl along when shopping for clear tube. Test fit before purchasing. Or splurge by getting a couple of different o.d. size 1 foot lengths. This of course refers to common soft flexible clear tubing, and not a rigid plastic pea-shooter type tube. Good Fortune! |
Last Edit: 2 years 11 months ago by Patton.
