  • Page:
  • 1
  • 2
Spark plugs 11 Mar 2024 14:32 #896295
  • Slj029
  • Slj029's Avatar Topic Author
  • Thank you received: 6
I bought new plugs for my 79 1000LTD and when I went to install them they have a solid top terminal and the ones in my bike are threaded (pictures attached). I cannot seem to find this style anywhere?? The plug wires I have will not accept the solid style (too big).
You do not have permissions to access this page.
Spark plugs 11 Mar 2024 14:47 #896297
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2708
Those are resistor plugs.  Your bike takes B8ES, not BR8ES.  Alternate, ND W24ES or W24ESU.  The ND's might be easier to find.
www.amazon.com/Denso-W24ES-U-Spark-Plugs-Pack/dp/B005BR1DF8
The following user(s) said Thank You: asphalt900, SWest, 78kawltd, Slj029
Spark plugs 11 Mar 2024 14:47 #896298
  • gordone
  • gordone's Avatar
  • Thank you received: 67
Just unscrew the top terminal?
Project:
Spark plugs 11 Mar 2024 16:19 #896301
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
Thanks ED just ordered a set.
Last edit: by SWest.
Spark plugs 11 Mar 2024 17:19 #896303
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 357
With NGK they have different versions of the BR8ES.
One has a removable terminal nut. The other version has a solid terminal nut. You must have purchased the solid terminal 7986 BR8ES. The removable terminal nut plug is 5422 BR8ES.
The non-resistor B8ES is number 2411 and it looks like Napa has stock online.
www.napaonline.com/en/p/NGK2411
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Spark plugs 12 Mar 2024 03:11 #896311
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
Ditto F64's info but..I believe NGK ceased production of the Non-Resistor plugs? There may be left-over stock in some warehouses though? For a while i was buying up local bike shops inventory on the B8ES. There seem to be Chinese copy cat versions out there so be leary and informed about that! NGK actually did a write-up how to detect a fake. Honda part# 98079-58840 is an option as it too is a NGK B8ES, just their equivalent assigned number.
Spark plugs 12 Mar 2024 05:28 #896314
  • sf4t7
  • sf4t7's Avatar
Wanted non-resistor plugs and didn't want to take a chance of ending up with fakes, so I went with the ND W24ESU plugs for my Z1.
And when Rick Stetson machined and built my engine back in the 80's those are the plugs he recommended.  I figure a racer from the New England drag racing hall of fame knew what worked.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Last edit: by sf4t7.
Spark plugs 12 Mar 2024 08:42 #896323
  • Nessism
  • Nessism's Avatar
Straight from the factory service manual...
Spark plugs 12 Mar 2024 09:02 #896324
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 684
Not sure which model bike we're talking about but certainly on 650's that was the original recommendation however it was quickly changed to7's and 22's by a service bulletin as on normal road use 8's/24's were found to be too cold and easily fouled.
Z1000J2 somewhat modified!
Spark plugs 12 Mar 2024 09:27 #896326
  • Nessism
  • Nessism's Avatar
The OP has a KZ1000.
The following user(s) said Thank You: Warren3200gt
Spark plugs 13 Mar 2024 05:23 #896354
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 656
We see ND W24ES-U plugs languishing cheap at bike shop closeouts & swap meets often because few people seem to know what they cross from / to or fit.  Same with correct SplitFire plugs.  Both run fine.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
The following user(s) said Thank You: 78kawltd, howardhb
Spark plugs 14 Mar 2024 04:10 #896384
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1043
Gordone is correct.  Just unscrew the top on the plug on the left.  But from what I can see the plug on the right is fine.
  • Page:
  • 1
  • 2
