  • Page:
  • 1
  • 2
Clutch brand 04 Jan 2024 14:58 #893586
  • Maxbou92
  • Maxbou92's Avatar Topic Author
  • Thank you received: 0
Hello, Im looking to have a Spare clutch kit,  I found Vesrah clutch disc on ebay, Ebc, barnett. Can you give me your opinion about that. What kind of Oil do you put in your bike?! I have break my new engine with Castrol 10w40(mineral) for 600miles.. does Castrol is a good oil for the bike ?
Thank youu
Last edit: by Street Fighter LTD.
Clutch brand 04 Jan 2024 15:25 #893587
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2708
My first choice would be OEM plates.  They are expensive, though.  EBC is decent.  Vesrah is okay.  Barnett clutches have thin ears that can notch out your clutch basket.  I'd stay clear of those.  For springs, new OEM springs.  The aftermarket springs are hard to pull.  A new OEM clutch cable is a thing of beauty.  Get a GPz version if your bikes handlebars are lower than stock.
For oil, Castrol motorcycle oil will be fine.  I use diesel engine oil in my motorcycles, and it works fine.
Clutch brand 04 Jan 2024 15:34 #893588
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
Thank youu
You need JASO-MA rated oil. I use Shell Rotella T4
Last edit: by Mikaw.
Clutch brand 04 Jan 2024 15:40 #893589
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
  • Thank you received: 64
Thank youu
Yes on this! JASO-MA only.
Do not use synthetics with "friction modifiers". Your clutch plates will have a very short life.
I also use Shell Rotella T4 diesel 15W-40. It's safe to use with a wet clutch...
Available @ Wally...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Clutch brand 04 Jan 2024 16:04 #893591
  • Maxbou92
Thank you guys!! I haven’t found OEM clutch!! I have put Barnett springs last year .. happy with it!!  Do my Castrol 10w-40 or 20w-50 oil car is not good ?! I appreciate
Clutch brand 04 Jan 2024 16:33 #893593
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 94
Like everyone says OEM plates and springs. You really don't need Barrnet springs unless your drag racing a lot . They are typically a harder pull over stock and will be harder on your hand and the cable.
Clutch brand 04 Jan 2024 16:59 #893597
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
You are correct. Do not run that oil, run what was suggested.
C.
Last edit: by !Seymore.
Clutch brand 04 Jan 2024 22:04 #893602
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2091
Factory friction plates available here.
www.partzilla.com/catalog/kawasaki/motor...ch-81-82-kz750-e2-e3
Clutch brand 04 Jan 2024 22:34 #893603
  • TexasKZ
  • TexasKZ's Avatar
Seems to be a lot of chatter about Rotella foaming quite a bit.
bobistheoilguy.com/forums/threads/m1-0w-...lla-t6-5w-40.376388/
Clutch brand 04 Jan 2024 22:54 #893606
  • Maxbou92
All right, I’ll call Partzilla tomorrow
thank yoyu
Clutch brand 04 Jan 2024 23:18 #893607
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
thank yoyu
Check ebay too!  See item 266387182941
1982 KZ1100-A2
Clutch brand 05 Jan 2024 01:11 #893610
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Those are not Kawasaki engines... Kawi is NOT motioned anywhere there, but BMW fuel injector turbo is...
OH, and a bunch of caca! ...after reading a bit.
Looks like modified 4 cyl engines, nothing I would worry about for our engines.. (unless the mix changed)
C.
  • Page:
  • 1
  • 2
