  • Page:
  • 1
KZ1000 Oil Flow Path 02 Jan 2024 16:35 #893451
  • MJinCO
  • MJinCO's Avatar Topic Author
  • Thank you received: 0
New to the KZ motors, what is the oil flow path?  How does oil get up to and back down from the cam area
KZ1000 Oil Flow Path 02 Jan 2024 17:18 #893453
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1991
Manual has a diagram
Oil pump to main gallery
up the outside rear  cylinder studs ( Around them , not thru them )
then thru head passages to cams
Oil gravity flows down to sump thru cam chain  tunnel in center of motor
KZ1000 Oil Flow Path 03 Jan 2024 06:41 #893485
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 656
From The Z1 'White Manual'.  Doesn't illustrate well the continuous-flow splash output to the starter gear/dyno area.  Your KZ1K is the same.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: by slmjim+Z1BEBE.
KZ1000 Oil Flow Path 06 Jan 2024 11:19 #893689
  • MJinCO
Thank You, that helps a lot.
KZ1000 Oil Flow Path 06 Jan 2024 16:40 #893701
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
From the Kawasaki 1978-80 KZ1000 FSM pdf. It may be linked here on KZR.
The manual has several paragraphs describing the engine lubrication.
Last edit: by martin_csr.
  • Page:
  • 1
