  • Page:
  • 1
  • 2
KZ440 Ignition issues 21 Dec 2023 12:35 #892992
  • WokkaBuggyBuilder
  • WokkaBuggyBuilder's Avatar Topic Author
  • ^I'm building a KZ440 powered buggy^
  • Thank you received: 2
Wondering if this set up is even capable of producing spark, could be stressing over my own stupidity
It'll be fine...?
KZ440 Ignition issues 21 Dec 2023 13:10 #892994
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1899
Just making sure you 100% know my situation and set up right now.
I don't even have an ignition switch or starter relay on it right now, I just turn it over with a big cable. Is this how it's supposed to be wired as simple as possible? Can you spot anything that would eliminate spark? I mean seriously, I don't even have a loom, or fuses yet. Low oil pressure is not hooked up to anything. The color brown on the rectifier is the only one that was different from the wiring diagram I was using, so I ignored it and hooked it up in the orientation it was on the diagram regardless of color. See the picture
I will do you a diagram in the morning, what you have at the moment will never work
KZ440 Ignition issues 21 Dec 2023 13:15 #892995
  • WokkaBuggyBuilder
Well... simply it being wrong is me getting somewhere! I didn't know where to look. Here I am thinking I need to buy more parts when it's wrong from the beginning. Thanks in advance, for the diagram
It'll be fine...?
KZ440 Ignition issues 22 Dec 2023 01:57 #893003
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
OK so here is a basic diagram that should do all you want, also I have included a switch panel that will cover "Ign, Start & oil warning"
The following user(s) said Thank You: howardhb, WokkaBuggyBuilder
KZ440 Ignition issues 22 Dec 2023 09:12 #893013
  • WokkaBuggyBuilder
Well right off the bat I can see what I've done wrong... Thanks a bunch for that I'll try it out today!
It'll be fine...?
KZ440 Ignition issues 22 Dec 2023 15:22 #893031
  • WokkaBuggyBuilder
She SPARKS! IT FIRES! It's perfect man, thanks a ton. I thought I might of wasted 5 big ones on a motor I couldn't fix!
It'll be fine...?
KZ440 Ignition issues 22 Dec 2023 15:33 #893032
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Ladies and gentlemen "we have a winner"
The following user(s) said Thank You: WokkaBuggyBuilder
KZ440 Ignition issues 22 Dec 2023 19:26 #893042
  • WokkaBuggyBuilder
She's a runner! I've even tuned it already. Sounds like a beast man
It'll be fine...?
Last edit: by Wookie58.
  • Page:
  • 1
  • 2
