Piston Hole Kz1000LTD 1982 02 Apr 2024 03:28 #897155
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
That exact decal is available from Ebay for cheap!
I bought one, it is an exact fit.
Seach for item 204117469592
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: cartal, Wookie58
Piston Hole Kz1000LTD 1982 02 Apr 2024 07:44 #897156
  • cartal
  • cartal's Avatar Topic Author
  • Thank you received: 69
Got it! Thank you!
Piston Hole Kz1000LTD 1982 05 Apr 2024 16:25 #897300
  • cartal
Engine and frame have been reunited again. Let's go!
The following user(s) said Thank You: sf4t7, howardhb, Wookie58, Rolf1976_KZ900
Last edit: by cartal. Reason: Pic add
Piston Hole Kz1000LTD 1982 08 Apr 2024 14:16 #897390
  • cartal
Wookie, your parts look amazing!
I just love this part. Is like building a full size puzzle…
Piston Hole Kz1000LTD 1982 08 Apr 2024 16:31 #897395
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1945
Glad to see those parts helping you out rather than sitting in a box gathering dust
Piston Hole Kz1000LTD 1982 12 Apr 2024 16:46 #897584
  • cartal
Had to wait for new swing arm rollers to come through. Old ones were totally destroyed and. Made no sense to use them with new bearings.
i was dreading this, but getting the bearings in the freezer for a while and lots of oil made it really simple. Moving on….
The following user(s) said Thank You: howardhb, Wookie58, Rolf1976_KZ900
Piston Hole Kz1000LTD 1982 13 Apr 2024 14:37 #897604
  • Benjoe
  • Benjoe's Avatar
No eBay APP ID and/or Cert ID defined in Kunena configurationBonjour de France.
J'ai trouvé cet autocollant ici :
C'est pour Z 1000 J mais c'est le même pour la 1000 LTD
Piston Hole Kz1000LTD 1982 25 Apr 2024 03:20 #898095
  • cartal
Have not been posting for a while; I don´t want to get too intense and bore you guys. Some steady advance on the project. Here´s how it is standing:  Going throught the wiring. Some wires have been cut and joined. The lightning support box was missing and wiring redone. Trying to figure out routing, but it´s a question of trial and error.
Engine looks beautiful on the freshly painted frame... love it!
Another post coming with a question on shocks...
The following user(s) said Thank You: Rolf1976_KZ900
Piston Hole Kz1000LTD 1982 25 Apr 2024 03:22 #898096
  • cartal
One more engine pic...
Then, a little detail I really wanted to get done in this bike. Oil pressure gauge.
Last edit: by cartal. Reason: pic order
Piston Hole Kz1000LTD 1982 25 Apr 2024 03:28 #898097
  • cartal
Here´s the shock question. I bought a set of Yamaha SR500 shocks from YSS. They were 20 euro at a flea market, and are brand new... and they look awesome.
They are 2 cm shorter than the original, which I believe is no problem; but I am concerned if they will be able to hold the weight of the LTD, as the SR is an 80kg lighter bike.
Have installed one (provisionally), and I love the looks.
What do you think?
Pic for reference
The following user(s) said Thank You: Vinsky
Piston Hole Kz1000LTD 1982 25 Apr 2024 04:18 #898101
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Hi Carlos, bike is looking really good.
A couple of things (IMHO) the oil pressure gauge is a useful addition but I think the scale is too great for the extremely low pressure these roller bearing cranks run at which I believe is around 3.0psi (check the manual) I have put a picture below of one I think would be better
With the shocks, given that they are already shorter than stock and the spring rates are intended for a much lighter bike I think the rear end will sit very low and the handling is likely to be "interesting"
PS: Hope you don't feel I'm being negative
Piston Hole Kz1000LTD 1982 25 Apr 2024 05:26 #898104
  • cartal
Not at all! No negativity. This is exactly the kind of feedback I´m looking for.
I really though it was 3 bar the normal oil pressure, that´s why I got a 10 bar gauge.
But... looks like I screwed in the metrics! I just looked again, and yes; I bought the wrong one!
kzrider.com/forum/2-engine/597384-1976-kz900-oil-pressure
My bad!.
Thank you for pointing out, Wookie!
