  • Page:
  • 1
  • 2
KZ750 "twingle" 20 Jan 2017 10:27 #752548
  • Mk2Rookie
  • Mk2Rookie's Avatar Topic Author
  • Thank you received: 3
About excessive wear on the crankshaft, the rod bearings will see the same force either way since it will be the same bore and CR. So the wear will be on the main bearings and camchain. But everybody always says the main bearings are very strong ...
KZ750 "twingle" 20 Jan 2017 10:42 #752549
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Mk2Rookie wrote: My Yamaha SR500 has a decompression lever but is not too bad to start without it. Can you explain more about why the balancing shafts will make it worse ?
I'm not saying it will make it worse. It's there to lessen perceived vibration. I worked on one that had it come apart. The thing hopped around on it's centerstand like mad. Opened it up to find it was out of sync due to broken parts. Got new ones and it vibrated but it ran good enough to ride. As said before, if just changing the cams, it could be set back as it was if it was too bad.
KZ750 "twingle" 20 Jan 2017 10:51 #752550
  • Mk2Rookie
Yes that's why I want to try it, within an hour it can be returned to stock. I am still waiting to hear from the machine shop, I have no idea what that kind of work will cost. So far I have only heard of 1 shop in Denmark that is capable of doing it.
KZ750 "twingle" 20 Jan 2017 11:44 #752553
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
i know the "re-phased" xs650's sound awesome.
to bad the kz doesn't have a multi piece crank :whistle:
it'll be cool to see how you come out.
keep us posted,
KZ750 "twingle" 20 Jan 2017 12:10 #752555
  • Mk2Rookie
The rephased XS650 is pretty cool ! I have been reading a lot about, almost made me want one. But I really don't need 2 twins !
KZ750 "twingle" 20 Jan 2017 13:47 #752558
  • SWest
  • SWest's Avatar
  • 10 22 2014
The XS 650's were good bikes. B)
KZ750 "twingle" 20 Jan 2017 17:12 #752577
  • AtLarge
  • AtLarge's Avatar
  • Thank you received: 21
Can't help you with your question but, I am interested to know how this works out for you. Good luck. :)
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
KZ750 "twingle" 20 Jan 2017 19:32 #752583
  • azman857
  • azman857's Avatar
  • Thank you received: 111
I have an '80 XS 650. I've done some minor mods to her to suite me. I'm on XS650.com as azman857 if you want to check out my girl. They are great bikes.
Getting backto your "twingle". Do it. Let us know how she goes. Should be a real stump puller! Thump away!
Last edit: by azman857.
  • Page:
  • 1
  • 2
