usernamedoug wrote: They claim is direct fitment although it is missing red and white wire going to starter sol. From other threads this may not be necessary with the newer style rec but why doesn't it charge then???
Looking at a different wiring diagram this red/white wire is definitely the output lead which is not present on the new unit.
If I swap the positive output over the the correct pin in the 6P connector, is it sufficient to run the auxillary (headlight brakelight, horn etc) off the battery as long as I know its getting adequate charge?
