zr7 motor in KZ750 06 May 2016 11:38 #724908
  • GPzMOD750
  • GPzMOD750's Avatar
  • Thank you received: 148
Do the oil pans interchange? I could use another pan but GPz pans are hard to find. Not to mention an easy way to upgrade to a cooler if needed.
zr7 motor in KZ750 06 May 2016 11:56 #724913
  • riturbo
  • riturbo's Avatar
  • Thank you received: 277
GPzMOD750 wrote: Do the oil pans interchange? I could use another pan but GPz pans are hard to find. Not to mention an easy way to upgrade to a cooler if needed.
Not really the turbos have a sump pan for the scavenger pump .
I might have a na pan . Have to look in my spares .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
zr7 motor in KZ750 06 May 2016 12:57 #724920
  • turboguzzi
  • turboguzzi's Avatar Topic Author
  • Thank you received: 72
the zr7 pump i mounted in the past was in my gpz 750/810 road racer. with 90 rwhp temps can get really high in racing, you're constantly on full throttle/high revs for 25 mins and oil gets scaringly thin when really hot, the extra flow i see as cheap insurance. a tuner friend runs every now and then an oil pressure gauge and by mid race oil pressure drops quite a bit. would do this change in a street bike only if i lived in very hot weather, carry high loads, etc. never thought that my kz750E REALLY needed the bigger pump in northern italy weather.
the zr-7 pan is really like the gpz's, if anyone is thinking of a bolt on way to have a cooler.
Last edit: by turboguzzi.
zr7 motor in KZ750 06 May 2016 13:04 #724921
  • GPzMOD750
I don't have a turbo just a 82 dual track. I was wondering if the ZR will fit. My plug is stripped out and I have to wrap it with Teflon on a double oversized plug to keep it from dripping. I can make a steel sleeve to repair it but I'd like to have a spare just in case and so I can take my time without having the bike down.
I thought I found one on eBay but once I got it the oil cooler fittings we just blanked out and not drilled. It was black but it must haves been for a L, P or 700.
The seller was cool about it, he refunded my money and told me not to worry about sending it back.
zr7 motor in KZ750 06 May 2016 13:07 #724923
  • GPzMOD750
turboguzzi wrote: the zr-7 pan is really like the gpz's, if anyone is thinking of a bolt on way to have a cooler.
Well then, that opens up my options.
zr7 motor in KZ750 06 May 2016 13:27 #724928
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
I think the ZR7 oil pan is basically same as the GPz and later model 750 w/oil cooler pans. I put one on my 750E2 and it's a straight bolt on.
zr7 motor in KZ750 06 May 2016 14:07 #724933
  • Daftrusty
  • Daftrusty's Avatar
  • Thank you received: 184
***The zr-7 oil pan does not have the hole for the oil level switch that the gpz's normally have. The spot for the hole is there but it is not milled out.***
That's why I chose to use the zr-7 pan and not the gpz pan, as I would have had to make a block off plate for the oil level switch hole that the kz750e's do not have.
Last edit: by Daftrusty.
Saving a 1980 750 twin. 06 May 2016 14:34 #724940
  • GPzMOD750
IDK what happened there
Last edit: by GPzMOD750.
zr7 motor in KZ750 06 May 2016 14:36 #724942
  • GPzMOD750
Daftrusty wrote: ***The zr-7 oil pan does not have the hole for the oil level switch that the gpz's normally have. The spot for the hole is there but it is not milled out.***
Not an issue....
zr7 motor in KZ750 06 May 2016 14:53 #724949
  • Daftrusty
No kidding! :laugh:
zr7 motor in KZ750 06 May 2016 17:18 #724962
  • GPzMOD750
Whre's the ZR switch mount? Would it be better to use one of those if using a ZR pump and relief valve?
zr7 motor in KZ750 07 May 2016 03:04 #725021
  • turboguzzi
interesting, my european z750 (that's how KZs were called here in italy) didnt have the switch... my two gpz 550 / 750 did...
ripped off the whole internal thing and used the switch external plate as a blank off :)
