  • Page:
  • 1
  • 2
Stripped out 07 Oct 2015 16:53 #693710
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
JimB wrote: they make taps for shallow holes that you can buy.
It's called a bottoming tap and you can find lots of them but you are not going
to find one that cuts the threads for a helicoil. without paying out the ass.
I've been using Helicoil's for about 40 years and have F'ed up a BUNCH
learning how to do them right.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Stripped out 07 Oct 2015 16:59 #693711
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2634
At $35 a tap, it gets expensive quick.
Stripped out 08 Oct 2015 02:33 #693743
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1628
Another possible option is to use an 8mm stud.
The following user(s) said Thank You: DobbinsCMA
Stripped out 08 Oct 2015 03:51 #693751
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
Use a 8 and 6mm step stud.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
The following user(s) said Thank You: Patton, DobbinsCMA
Last edit: by Kidkawie.
Stripped out 08 Oct 2015 04:50 #693761
  • SWest
  • SWest's Avatar
  • 10 22 2014
Got a link? I might want to use them on my head.
Stripped out Exhaust Stud 08 Oct 2015 05:13 #693766
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
Wonder if you outta keep the step studs for a last resort ..... if you mess up a 6mm heli coil or time sert ?? Nice to know about.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Stripped out Exhaust Stud 08 Oct 2015 11:13 #693818
  • martin_csr
I agree --- an 8mm stud would be at the bottom of the list. The exhaust holder nuts don't require much torque, so the other repair options ought to be good.
Last edit: by martin_csr.
Stripped out Exhaust Stud 08 Oct 2015 12:41 #693829
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
Sorry for the thread drift, but if anyone has found a reasonable alternate source for the Kawasaki 6mm x 27mm stud please share. I need three. One issue I'm finding is that some companies spec studs like these by how much sticks out after install (this is how Kawasaki denotes the studs), but others list the overall length. At any rate, if anyone found a good source please let me know.
Stripped out Exhaust Stud 08 Oct 2015 12:47 #693830
  • Thank you received: 2829
Nessism wrote: Sorry for the thread drift, but if anyone has found a reasonable alternate source for the Kawasaki 6mm x 27mm stud please share. I need three. One issue I'm finding is that some companies spec studs like these by how much sticks out after install (this is how Kawasaki denotes the studs), but others list the overall length. At any rate, if anyone found a good source please let me know.
You may want to ask these folks for their specs on their 6mm x 27mm studs. Ed
id3528.securedata.net/test.burrisracing....id=1&products_id=498
Stripped out Exhaust Stud 08 Oct 2015 13:30 #693838
  • martin_csr
Assuming you mean a source other than the Kawasaki dealer, Z1Enterprises.com carries them.
Z1Ent --- exhaust studs
Z1Ent --- Exhaust Stud 6x27 Kawasaki --- 92004-066 --- $2.61 Ea
Stripped out Exhaust Stud 08 Oct 2015 16:10 #693859
  • Nessism
  • Nessism's Avatar
Yeah, checked out Z1 but they are out of stock and on the other side of the country from me.
Think I'm going to order from McMaster-Carr. A little price but good quality alloy steel and I can get them tomorrow.
  • Page:
  • 1
  • 2
