  • Page:
  • 1
Air Switch Valve - I know what you'll tell me… 26 Sep 2015 08:32 #692003
  • bl_francis
  • bl_francis's Avatar Topic Author
  • Thank you received: 10
that I should just get rid of it.
What exactly does this thing do? What's inside of it?
Can I clean it up? There seems to be a lot of gunk in it.
Any help is appreciated. Thanks in advance.
Attachment AirSwitchvalve.jpg not found
1987 KZ1000 Police
Air Switch Valve - I know what you'll tell me… 26 Sep 2015 08:47 #692004
  • Lazyman06
  • Lazyman06's Avatar
  • Thank you received: 3
If i'm not mistaken, it's a valve that directs the clean air from your reed valves back to your air box to be recycled.
There's a spring and diaphragm that opens and close to prevent too much air from going thru. (Now i'm pulling things out of my @$$)
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
The following user(s) said Thank You: bl_francis
Last edit: by Lazyman06.
Air Switch Valve - I know what you'll tell me… 26 Sep 2015 08:48 #692005
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
In the top (left side in the pic) is a vacuum operated valve. A small hose connects that small hose barb to a similar one on one of the carburetors. At the opposite end a hose connects the valve to the air box. The other two hose barbs are connected by hoses to the reed valve assemblies in the cam cover.
When vacuum is high (at idle or at higher rpm when the throttle is suddenly closed) the air valve is closed so that no air flows through the larger hoses. When vacuum is lower (during acceleration for example) the valve opens, allowing filtered air from the air box to be drawn through the valve and the reed boxes and finally through small ports ti the exhaust ports. This exta air ignights any unburned fuel before it exits the exhaust system. It is a fairly effective way to reduce certain pollutants without robbing horsepower.
As faras I know, there is no downside to having the system on the bike, other than esthetics.
Ivenever opened one, but I'd bet there is a rubber or vinyl diaphragm connected to a brass valve in it.
Last edit: by TexasKZ.
Air Switch Valve - I know what you'll tell me… 26 Sep 2015 09:02 #692006
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
If it is bad you can still get them from Partzilla, I think.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Re:Air Switch Valve - I know what you'll tell me… 26 Sep 2015 09:24 #692009
  • bl_francis
Thanks everyone. I took it off today to put on two new tubes that run to the engine. I was wondering if it would be okay to soak it in something to clean out the gunk. These are about $100 on Partzilla which is where i got the tubes.
1987 KZ1000 Police
Air Switch Valve - I know what you'll tell me… 26 Sep 2015 09:40 #692010
  • ThatGPzGuy
Will it hold vacuum? I don't know how else you would check them.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Re:Air Switch Valve - I know what you'll tell me… 26 Sep 2015 10:38 #692018
  • bl_francis
I tried plugging all of the hole but one or two and blowing in but no dice. I cant get any air to move through the small tube that goes to the carb.
1987 KZ1000 Police
Re:Air Switch Valve - I know what you'll tell me… 26 Sep 2015 10:40 #692020
  • bl_francis
Attachment ImageUploadedByTapatalk1443297427.191726.jpg not found
Attachment ImageUploadedByTapatalk1443297444.847896.jpg not found
Attachment ImageUploadedByTapatalk1443297458.990104.jpg not found
After some cleaning.
1987 KZ1000 Police
Re:Air Switch Valve - I know what you'll tell me… 26 Sep 2015 11:03 #692023
  • Kwaker2000
  • Kwaker2000's Avatar
  • Thank you received: 23
i had this system on my bike i completely removed all of it and plugged all the holes ,but i live in united kingdom so don't need to have it on legally ,put some nice ape billet covers on cylinder head . :)
Re:Air Switch Valve - I know what you'll tell me… 26 Sep 2015 12:19 #692030
  • ThatGPzGuy
bl_francis wrote: I tried plugging all of the hole but one or two and blowing in but no dice. I cant get any air to move through the small tube that goes to the carb.
You are probably fine then. As long as the small nipple that goes to the carbs will hold a vacuum.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Page:
  • 1
