  • Page:
  • 1
any pics on how the exhaust manifold shims are in? 29 Jun 2015 09:54 #678703
  • cott10r
  • cott10r's Avatar Topic Author
  • Motorcyclist for life!!!
  • Thank you received: 0
Im not sure if the exhaust manifold shims are on my little gpz550 properly, i was on a evening ride & devoloped an exhaust leak on the #3 cylinder, upon inspection i found the two headed bolts were loose causing my leak, but something looks off on the shims.
2012 kawasaki concours 14
2014 suzuki gsxr 1000
2014 honda crf 250L
1983 kawasaki gpz 550
any pics on how the exhaust manifold shims are in? 29 Jun 2015 11:47 #678719
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1628
KZRider topic --- 78 kz1000 exhaust question
Your bike probably has flanges welded to the header tips, instead of being flared, but the installation is the same.
The half-moon exhaust collars should be installed with their wide flared ends against the exhaust holder clamps.
Last edit: by martin_csr.
any pics on how the exhaust manifold shims are in? 29 Jun 2015 12:52 #678730
  • davido
  • davido's Avatar
  • Thank you received: 286
Are the nuts loose on the bolts or are the bolts themselves loose? (The bolts are usually threaded studs) If its just the nuts you should be ok,just realign everything properly and tighten them down. If its the bolts (studs) that are loose,Its going to be a bit more involved.
Good luck with it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
any pics on how the exhaust manifold shims are in? 30 Jun 2015 06:19 #678821
  • martin_csr
Don't over-tighten the exhaust studs --- they're only 6mm & I think the torque spec will be in the 69-INCH/lbs range (not ft/lbs). I would hate to snap off one of them.
  • Page:
  • 1
