KZ1000 Vibration 02 Aug 2015 17:51 #683982
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
You can get the shim out. Take a piece of cut off broom stick and tap on it until it gets free. Must have a burr in there. The valve springing back will help dislodge it.Use penetrating oil too.
The following user(s) said Thank You: Garbosh
KZ1000 Vibration 02 Aug 2015 17:55 #683983
  • Garbosh
  • Garbosh's Avatar Topic Author
  • Thank you received: 0
Ok, ill get the penetrating oil, fill it up, let it sit for a day then go out and beat on it.
82 KZ1000P
Café Racer/ Brat Project
-Clubman Bars
-End Mirrors
-Rear Shocks
KZ1000 Vibration 02 Aug 2015 18:38 #683987
  • SWest
  • SWest's Avatar
  • 10 22 2014
I don't think you have to do that. Just some tap,tap,tapping should do it. You'll hear when they free up. The lifters stick up so you can grab them by the lip and pull them out. Maybe with a slight twisting motion. Support the head on some blocks on the sides so the valves don't hit the bench.
Last edit: by SWest.
KZ1000 Vibration 02 Aug 2015 19:02 #683997
  • Garbosh
Good thinking on the block thing, I have them raised up enough to grab a hold of the but they are not budging, they wont twist or anything right now, so hopefully the penetrating oil does its job.
82 KZ1000P
-Clubman Bars
-End Mirrors
-Rear Shocks
KZ1000 Vibration 02 Aug 2015 19:29 #683999
  • SWest
  • SWest's Avatar
  • 10 22 2014
MAN, you really must have munged them up. Keep on it and let us know.
KZ1000 Vibration 02 Aug 2015 20:01 #684007
  • Garbosh
Both were stuck in the downward position. I was able to tap on the valve side to get the back to normal, so they move....just with difficulty is all.
82 KZ1000P
-Clubman Bars
-End Mirrors
-Rear Shocks
KZ1000 Vibration 02 Aug 2015 21:15 #684014
  • SWest
  • SWest's Avatar
  • 10 22 2014
Don't hit the valve with metal. They might be bent.
KZ1000 Vibration 02 Aug 2015 21:22 #684017
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Garbosh wrote: Both were stuck in the downward position. I was able to tap on the valve side to get the back to normal, so they move....just with difficulty is all.
Ouch!! Sounds like bent valve stems to me .
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
KZ1000 Vibration 02 Aug 2015 21:23 #684018
  • SWest
  • SWest's Avatar
  • 10 22 2014
YUP :(
KZ1000 Vibration 02 Aug 2015 21:47 #684023
  • Garbosh
Im just going to pretend that was not read ha
82 KZ1000P
-Clubman Bars
-End Mirrors
-Rear Shocks
KZ1000 Vibration 02 Aug 2015 21:48 #684024
  • Garbosh
Would you be able to visually tell if they made contact with the pistons?
82 KZ1000P
-Clubman Bars
-End Mirrors
-Rear Shocks
KZ1000 Vibration 03 Aug 2015 05:13 #684034
  • SWest
  • SWest's Avatar
  • 10 22 2014
Turn the head upside down and fill the chambers with gas. You will know in an instant which valves are bent.
