  • Page:
  • 1
Engine Cracked 02 Mar 2015 22:29 #663270
  • nickleo373
  • nickleo373's Avatar Topic Author
  • Thank you received: 33
Hey everyone
I bought a second KZ550 a while back that I've slowly been working on. I checked the valve clearances and while I was putting the valve cover back on I noticed the previous owner had somehow driven the cam end valve cover bolt through the bottom of the head. Is this something a machine shop would be able to fix or is the entire head ruined?
1981 KZ550C LTD
"If you ain't first, you're last"
Engine Cracked 03 Mar 2015 01:11 #663273
  • davido
  • davido's Avatar
  • Thank you received: 286
Have you got a photo?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Engine Cracked 03 Mar 2015 05:23 #663283
  • Thank you received: 2829
It should not be a problem at all. Check to see if the other holes for the cam end valve cover bolts go all the way through. I suspect you'll find that they do; I know they do on the KZ650.
Is the bolt actually sticking through the bottom of the hole? If so, the owner used too long a bolt. He may have done that on purpose to gain more purchase on the threads if he overtightened the original bolt and stripped the upper section of the threads. Ed
Engine Cracked 03 Mar 2015 12:04 #663326
  • nickleo373
Thanks for the replies. Here's a photo of the broken pieces. Both sides look the same and are broken in the same way. The front cam ends appear to be unbroken. Will the engine hole oil like this or is it something that will need to be repaired before it can run?
1981 KZ550C LTD
Engine Cracked 03 Mar 2015 19:36 #663388
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
I've had this before, not worth scrapping a head for imo.
just add some sealant on the rubber cam boring blanking inserts if it leaks.
The following user(s) said Thank You: nickleo373
Engine Cracked 03 Mar 2015 19:41 #663389
It looks bad, but might not leak. If you put in the correct bolts you may want to patch the broken sections with some JB weld to see if that will hold up ok. Ed
Engine Cracked 03 Mar 2015 22:15 #663404
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 633
650ed wrote: It looks bad, but might not leak. If you put in the correct bolts you may want to patch the broken sections with some JB weld to see if that will hold up ok. Ed
The same holes on a 1100 J-model were not factory-tapped all the way through, on the two heads I have. While chasing threads, they were carefully finished out through the bottom to allow for slightly longer bolts. :)
1982 KZ1100-A2
Engine Cracked 05 Mar 2015 16:50 #663587
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
If you look close that bolt boss is not done breaking.
In the pic there's two cracks I can see.
one from the bottom of the rubber plug and one next to it
that run's up to the valve cover surface.
They could be welded without pulling the head.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Engine Cracked 05 Mar 2015 19:58 #663606
  • nickleo373
Thanks zukdave. I completely missed that. I just went outside to check it out and it doesn't appear to be a crack. It looks like the head may have been welded before and someone used a grinder to hide that it had been welded. :huh:
1981 KZ550C LTD
  • Page:
  • 1
