Porting and milling options for GPZ750? 09 Dec 2014 15:08 #655715
  • taylee
  • taylee's Avatar Topic Author
  • Thank you received: 1
1985 GPZ750 and the whole bike is a mess, so I’m tearing everything down, including the engine to make sure it’s all to spec.
While apart I thought I would have a mild porting and milling of the head to get a little bit more performance. I don’t want it to be a racebike, but I do want it to have a bit more ooommph and set itself apart from the KZ750 and stock GPZ750. What can I do that will give me that and still allow it to be reliable and use pump gas?
1985 GPZ750 (non-turbo)
Porting and milling options for GPZ750? 09 Dec 2014 15:49 #655717
  • azman857
  • azman857's Avatar
  • Thank you received: 111
just getting rid of sharp edges and blending of the ports will give you a boost. Not a big boost but careful work with a dremmel will work. Lap in the valve seat while your at it.
Porting and milling options for GPZ750? 09 Dec 2014 15:58 #655720
  • Thank you received: 2829
Milling? Be careful. Ed
The following user(s) said Thank You: PLUMMEN
Porting and milling options for GPZ750? 09 Dec 2014 16:17 #655724
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
Id would start by seeing how far down the highest piston is down the hole,then if theres any extra room to spare id pop the sleeves out then deck bottem of the cylinder if it was me anyway.
Id never deck a head any more than is required to make sure its flat,cylinders are a lot easier to space/shim or replace than a head if plans change in the future.
As far as porting the head,bigger isn't always betterVelocity is more important than large amounts of volume. :)
Porting and milling options for GPZ750? 09 Dec 2014 16:23 #655726
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
650ed wrote: Milling? Be careful. Ed
ED it's ok to mill a head you just need to stop right about here.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Porting and milling options for GPZ750? 09 Dec 2014 18:32 #655736
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2081
OMG
Porting and milling options for GPZ750? 12 Dec 2014 16:59 #655926
  • taylee
So .003 off the head? Anyone else have anything to say about this amount?
Porting and milling options for GPZ750? 12 Dec 2014 17:06 #655929
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2696
taylee wrote: So .003 off the head? Anyone else have anything to say about this amount?
The valve seats are too close to the deck surface to allow milling such that you will increase compression. I'd have the head surfaced taking off the minimum amount of material possible to get a smooth surface and then stop there.
Last edit: by Nessism.
Porting and milling options for GPZ750? 12 Dec 2014 17:09 #655930
  • taylee
Gotcha. So you are talking the bottom of the cylinder head?
What of using a thinner head gasket? Are those available?
Porting and milling options for GPZ750? 12 Dec 2014 17:17 #655933
  • Nessism
  • Nessism's Avatar
  • Away
taylee wrote: Gotcha. So you are talking the bottom of the cylinder head?
Yes, the bottom of the head. Honestly, you don't need to mill it and I wouldn't, unless you have reason to question the quality of the sealing surface. Have your machine shop take a cleanup pass if you are concern about the sealing, otherwise I'd leave it alone.
Not sure about thinner head gaskets. I doubt you can make a meaningful change that way, other than you may get leaks.
Porting and milling options for GPZ750? 12 Dec 2014 18:27 #655935
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
Another option is to use three bond instead of a base gasket.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Porting and milling options for GPZ750? 12 Dec 2014 19:22 #655941
  • Nessism
  • Nessism's Avatar
  • Away
Nebr_Rex wrote: Another option is to use three bond instead of a base gasket.
Surely you jest. Right? :S
