  • Page:
  • 1
Starter delete 14 Nov 2014 19:46 #653734
  • vondikka
  • vondikka's Avatar Topic Author
  • Thank you received: 0
I want to remove the starter on my kz650. I'm wondering how I should seal the hole that it's in. Any suggestions?
78 KZ650 C2
76 kz400 D3
Starter delete 15 Nov 2014 02:11 #653739
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
Use an appropriately sized automotive freeze plug.
Either a normal type or the expanding universal kind
Past; 78 kz1000, 83 kz550
Andrew
Starter delete 15 Nov 2014 07:01 #653747
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2081
If you prefer blingy.......
kzzone.com/starterplates.html
Starter delete 15 Nov 2014 07:27 #653748
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 122
TexasKZ wrote: If you prefer blingy.......
That will not work on KZ650 as it drives internal.
1984 750 Turbo
Starter delete 15 Nov 2014 09:46 #653754
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
On a 550 racebike I had the starter motor hole was blanked with an alloy 'top hat' collar.
Re:Starter delete 17 Nov 2014 23:33 #654025
  • vondikka
Thanks. I'll look into those
78 KZ650 C2
76 kz400 D3
Re:Starter delete 18 Nov 2014 20:10 #654102
  • vondikka
I just found starter hole plugs at Z1 enterprises
78 KZ650 C2
76 kz400 D3
  • Page:
  • 1
