  • Page:
  • 1
'79 KZ400B WET STATOR? 19 Oct 2014 17:22 #651167
  • ShaCvet
  • ShaCvet's Avatar Topic Author
  • Thank you received: 1
I have a '79 KZ400B
I pulled the stator cover off to access the starter for removal. Is the stater a wet or dry? Bunch of oil came out...
1979 KZ400 B2 fully restored and powder coated.
Last edit: by ShaCvet.
'79 KZ400B WET STATOR? 19 Oct 2014 17:45 #651170
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
Look for the hole in the case.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
'79 KZ400B WET STATOR? 20 Oct 2014 10:11 #651236
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Anytime you have the starter clutch attached near the alternator, there is usually a way for oil to get there (as the starter clutch needs it). But the oil is not needed by the alternator.
On the 650/700/750-4 and 500/550/400-4, the starter clutch is inside the engine, so the alternators are dry.
The 400/440 twins and 750 twins and 900/1000 have the starter clutch near the alternator, so they will spill some oil when you take the cover off.
  • Page:
  • 1
