Yoshimura exhaust interchangability
  • barney
  • barney's Avatar Topic Author
08 Oct 2014 07:49
#650060
Hey
I have a line on a Yosh header however im confused (more than usual). The seller says it will fit a Kz750 Kz900 Kz1000 as well as a GS1000. Any thoughts? Im putting it on a 831000J. I know for a fact kerkers will interchange between KZ900's and 1000J's
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Yoshimura exhaust interchangability
08 Oct 2014 09:45
#650071
I'd be skeptical...remember that old-school Suzuki inline fours have a forward tilt to the cylinders while Kawasaki cylinders are almost vertical. So, while the cylinder spacing may be very similar, You'll end up with some very odd angles to the collector/muffler on a KZ if it was originally designed for use on a GS. I'd see if the header was originally designed for a KZ or a GS.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
08 Oct 2014 10:03
#650072
This is what a Yosh Series I for a KZ/Z1 looks like:
[img
161 by mmsmithgall , on Flickr
This is a Yosh Series II for a KZ/Z1:
[img
MMS_0907 by mmsmithgall , on Flickr
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
08 Oct 2014 10:42
#650073
The bottom photo looks suspiciously like a Bassani...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
08 Oct 2014 10:56
#650075
The small KZ's (650/750) have a different spacing, between the cylinders, than the big boyz (900+). So if it fits the 750, I doubt if it will fit your 1000. (correct me if I'm wrong on this)
Might ask for a measurement, center to center at the head, by the seller... then measure yours. Should tell you what you need to know...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • mtbspeedfreak
08 Oct 2014 12:42
#650081
Mcdroid wrote: The bottom photo looks suspiciously like a Bassani...
Nope, I can see why you'd say that though, it's just the angle of the picture. If it were on the bike, you'd see the muffler/megaphone section is not as large as a Bassani.
I can assure you, it's all Yosh.
[img
MMS_0915 by mmsmithgall , on Flickr
[img
MMS_0913 by mmsmithgall , on Flickr
2000 ZRX 1100
  • barney
08 Oct 2014 12:58
#650084
Thanks guys for chiming in . I am suspicious for sure. Fortunately I have a Kawy friend who lives close to the guy selling the header and he is going to try it on his project 1000j bike for me to verify either way. The seller is very open and accommodateing which helps out a lot
  • Arial Bender
  • Arial Bender's Avatar
08 Oct 2014 12:58
#650085
When I bought my Z1-R it had a Kerker on it and when I took it for a tune up they told me it was a 750 exhaust that was forced to fit.
78 Z1-R
