  • Page:
  • 1
Camshaft suggestions? 21 Sep 2014 17:54 #648304
  • 78kz650guy
  • 78kz650guy's Avatar Topic Author
  • Thank you received: 0
Hey guys,
I have my KZ650 pretty far apart right now and want to get the most improvement as i can out of it while it's apart.
My current mods are a kerker 4>1 header, pod filters, dyna s ignition system and drag bars (I know they for offer any performance gains but it sure looks faster B) )
I was looking on a few websites and found some options. does anybody have a suggestion on a good relitively bolt on cam that will go good with my current mods?
thanks in advance!
Camshaft suggestions? 21 Sep 2014 17:56 #648305
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
I think all the performance cams for 650/750s are welded up stockers that are remachined. ;)
Camshaft suggestions? 21 Sep 2014 19:13 #648317
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
750 cams have more lift and duration than 650 cams.
With stock pistons your limited to what can be done.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Camshaft suggestions? 21 Sep 2014 19:14 #648318
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
What about 1982 Gpz750 cams?
Camshaft suggestions? 22 Sep 2014 08:21 #648348
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
I put a 1980 KZ750 cam in mine and picked up a little ..... 304 lift stock and 330 on the 750 cam. 10 degree's more duration too.. make sure they will work with stock pistons though ..... the 700cc piston have plenty of cut out for clearance.
The GPZ cams would be a step up but then you need to shim em and not real sure if they will work with stock pistons.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Camshaft suggestions? 22 Sep 2014 13:27 #648363
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
83-85 GPz cam's will be the largest factory cam's out there.
All after market cam's are hard welded and reground stock cam's as there's
no new cam blank's made.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Camshaft suggestions? 22 Sep 2014 18:17 #648406
  • Nebr_Rex
  • Nebr_Rex's Avatar
zukdave wrote: 83-85 GPz cam's will be the largest factory cam's out there.
Unless you have some nos. B)
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Camshaft suggestions? 23 Sep 2014 10:05 #648502
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
The zx cams are hotter than the earlier GPz750R1 cams although I think there are clearance issues with the earlier pistons.
Sometimes less is more, back in the day the manufacturers were at war with each other all trying to squeeze max power out of established designs. What is nice about the z650 is the strong midrange pull which is good for most road use.
Camshaft suggestions? 23 Sep 2014 11:26 #648520
  • Tyler
  • Tyler's Avatar
  • Thank you received: 92
Here is some info I cut from the Megacycle catalogue... should give you an idea of what you can do.
Attachment Untitled.jpg not found
"74 Yamaha DT 400 Enduro
Camshaft suggestions? 23 Sep 2014 14:59 #648550
  • zukdave
  • zukdave's Avatar
Never heard of the factory selling cam blank's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Camshaft suggestions? 23 Sep 2014 16:56 #648565
  • Nebr_Rex
  • Nebr_Rex's Avatar
Not all aftermarket cams are hard welded. I have two sets that have never been
installed. They are Andrews grinds 10 an 15.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Camshaft suggestions? 23 Sep 2014 17:54 #648573
  • zukdave
  • zukdave's Avatar
Andrews cam's would not be NOS blank's
But yes Andrews did cast their own cam core's at one time
from what I've read.
Best I know if you want cam's for one of the Kaw. small four's
you got two choice's Webcam's or Magacam's and both will
be hardwelded on your core's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • Page:
  • 1
